I need fuel Injector retainer clips
Car: 1987 IROC Z
Engine: 350 TPI L98 block
Im in need of fuel injector retainer clips. Please tell me that I won't be forced to pay $9 for each clip. Thats (dealership) robbery. Does someone else have a better source for these?
PN 17111267
Does anyone have extras or ???
87 IROC TPI 5.7L
PN 17111267
87 IROC TPI 5.7L
Car: 1986 IROC-Z28
Engine: 355 in the works...
www.gmpartsdirect.com sells part #17111267 at $3.11 a piece.
Car: 71 Nova
Engine: Superramed 383, Topline heads
Axle/Gears: 8.2 posi 3.08
Not for nothing but i got into finding these clips. And the simplest thing i found was making my own with the right wire. Believe it or not the design for the clips are pretty simple to make.
Car: 92 Z28
Engine: 357 TPI (L98)
What do you need them for? You can go without them, assuming everything is bolted down properly and the injectors are lubed on the rings and snapped firmly into place.
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Well Jamesbob02,
You are correct in your comment, "assuming everything is bolted down properly". However, I am sure that you are as aware of what "assuming" can do as I am. Personnally, I have a rather strong dislike for this Murphy fellow and that strange law of his, you know the one. "If something can go wrong, it will". I think that I would much rather be safer than sorrier.
The Trickster!!!!!!!!!!
Car: 92 Z28
Let me rephrase that. KNOWING everything is bolted down properly, there should be no problems. The retainers do jack **** when the bolts are in tight and the injectors are placed correctly. There should not have to be any ASSumptions that this is done right; if you can't accomplish it, you shouldn't be working on your car because you are a hazard to yourself and people around you.
I don't like him either, but even Murphy would agree to that.
Car: 89 formula 350
Engine: ls1 magnuson tvs2300 supercharger
Axle/Gears: 4.11 Dana 44!
Originally Posted by Mkos1980
I went to the junk yard and got like 900 for free
Re: I need fuel Injector retainer clips
My choices are Napa, Auto Zone, Oreilly and Advance. Does anyone have any part numbers for these clips from these stores? I can't find anything on their web sites.
thx
craig
thx
craig
Car: 89 formula 350
Car: 91 TA
it also depends on what kind of injectors you have if you need the clips or not b/c my venom injectors wouldnt work w/o the clips
Firechicken86
Aug 12, 2015 10:07 PM
go figure.
