new pushrods w/ roller rockers?
Old Dec 11, 2003 | 08:21 PM
IROCZ88x's Avatar
Car: 1988 IROC-Z
Engine: LB9
hey im tearin up my valvetrain this spring and puttin in new lifters and some crane 1.5 self aligning roller rockers...can i use my stock pushrods if theyre in good cond? or should i? if i should replace them, with what specifically? thanks guys
Old Dec 12, 2003 | 07:15 AM
88305tpiT/A's Avatar
Car: 2016 Ram 1500
Engine: 3.0L Diesel
Transmission: 8sp
you can use them if the ends are ok and theyre not bent.
also excessive scoring where they go through the head is another place they wear.
Old Dec 12, 2003 | 01:07 PM
Insomniac92z28's Avatar
Car: 92Z28
Transmission: A4
They should work fine, but I would check the pattern on the valve tip to make sure the length is correct. It should be but check it and you will be sure you aren't hurting your guides.
slowsi
Oct 18, 2015 08:49 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
gixxer92
Sep 1, 2015 04:32 PM
SLNTSCPE
Aug 22, 2015 09:15 PM
