breaking 12s
Old Dec 10, 2003 | 08:20 AM
TPItransam85's Avatar
breaking 12s
this past season my best ET was a 13.16 @104.45 with a 2.01 60ft at cecil county this coming season i am looking to break into the 12's. my mods are a hooker cat back ported plentum home made cold air and a 125 shot of nitrous. i am tinking about buying a set of edelbrock TES headers and a new cat that im going to gut. what do u guys think about this. im kind of on a budget. can u help me out.
Old Dec 10, 2003 | 08:44 AM
IROCZZ3's Avatar
Car: 87 Buick GN
Engine: 3.8L (231 cid) V6
Transmission: 200-4R
Axle/Gears: 10 bolt G80/ 3.42
I'd buy a set of drag radials first.
Old Dec 11, 2003 | 08:33 AM
gmgod's Avatar
Car: 92 T/A VERT
Engine: LB9
Transmission: AUTO
Axle/Gears: 7.5 / 3.42's
I would'nt spend the money on a new cat if your going to gut it. Just take the outside part of your existing one and weld it around a 3 inch pipe.
Old Dec 11, 2003 | 09:26 AM
Thirdgen86TA's Avatar
Wow thats pretty good. I have a home made CAI, exhaust, high flow cat, accel coil, wires, ported plenum, slp runners, AFPR, and a 2400 stall and my best time was 15.1 in my 305TPI. Like they said either by a high flow cat if you have to pass emissions or just gut your stock cat. No point in payin lots of money for something you are just going to ruin.
Old Dec 11, 2003 | 09:28 AM
jichniow's Avatar
Car: 89 IROC-Z
Engine: 6.0L LQ4
Transmission: 4l60e
Axle/Gears: 3.70
What type of nitrous system do you have?
Could you just switch to a 150hp shot? That would be cheap.
Old Dec 11, 2003 | 10:41 AM
gen3z's Avatar
Car: '92 droptop bird
Engine: 5.7L,mild cam etc.
Transmission: modded 700r4 w/2600
a set of drag radials would be the best invesyment,chip from perf.resources,march underdrive pulleys,pull your plenum and port it,by no means install the 150hp pills if you want your 305 to last
Old Dec 11, 2003 | 03:39 PM
gixxer9's Avatar
Car: 86 IROC
Engine: 6.2
Axle/Gears: 10 Bolt 4.10
YEAH, I GOTTA SAY DRAG RADIALS TOO. THOSE 60 FT TIMES ARE TERRIBLE FOR A LOW 13 SEC CAR. OR ARE YOU SPRAYING AFTER SHIFTING INTO 2ND? IF YOU'RE SPRAYING OFF THE LINE YOU ARE LOSING AT LEAST 3/1OTHS BECAUSE OF NO TRACTION.
Old Dec 11, 2003 | 03:41 PM
gixxer9's Avatar
Car: 86 IROC
Engine: 6.2
I FORGOT TO MENTION THAT I'M PULLING 1.6 60 FOOTERS WITH DRAG RADIALS AT 23 PSI.
Old Dec 11, 2003 | 04:02 PM
gixxer9's Avatar
Car: 86 IROC
Engine: 6.2
I'M NOT TRYING TO START ANYTHING HERE JUST STRESSING THE IMPORTANCE OF SUSPENSION AND TRACTION. MY TRAP SPEED ISN'T IMPRESSIVE BUT I GET OFF THE LINE AWESOME AND GOOD 60 FOOTERS EQUAL GOOD E.T.'S.
Old Dec 11, 2003 | 04:20 PM
D Stroy H8's Avatar
Car: 1990 Iroc-Z
Drag Radials. No doubt.
The headers will get you into the 12's...
but it seems you have focused your ET on the nitrous. So I would help the nitrous, not the natural catch my drift? I have a pair of Nitto555R on the back of my car and they are great. Nice wet traction in case of rain, and they burn up very nice on the tarmac.
Old Dec 12, 2003 | 01:33 PM
N8MAN1068's Avatar
Car: 85 ta ws6 KITT
Engine: Lb9
Transmission: th350
nice times! it's comforting to know that should i use nitrous, i'll be a low 12sec car with my mods.....if your mods really are all you've done. i have a 85 305 with a th350.
UltRoadWarrior9
Apr 28, 2020 10:39 PM
apie2546
Oct 16, 2016 02:24 PM
ZekeThorpe
Theoretical and Street Racing
35
Oct 7, 2015 07:30 PM
sjorgens
Oct 1, 2015 07:54 PM
mfp189
Sep 27, 2015 09:25 AM
