sealing threads
Old Dec 15, 2003 | 05:58 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
sealing threads
Which bolts need to be sealed when doing an engine rebuild? I know the outside/bottom head bolts and the two lower water pump bolts. Are there more?
Old Dec 16, 2003 | 05:51 AM
ede's Avatar
ede
any bolt that goes to water, but i guess you knew that. just so i don't get confussed i seal all head, water pump, fuel pump, intake and the right front motor mount.
Old Dec 16, 2003 | 06:14 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Yeah, I knew that :lala:
I guess it's better to be safe..
Old Dec 18, 2003 | 03:26 PM
JakeJr's Avatar
Car: 1996 Vette / 1992 GSX1100F Suzuki
Engine: 1996 Corvette Coupe 388 LT1 (+.060)
Axle/Gears: 3.07
You also want to use anti-seize on any bolt that screws into aluminum. I even use it on the spark plug threads.
I always use Permatex #2 on the head bolts; teflon tape on all pipe threads (leaving the first two threads bare).
Lock-Tite on torque converter, harmonic dampner, crank pulley, flexplate to crank and camshaft gear bolts.
Hope this helps.
Jake
Old Dec 20, 2003 | 09:24 AM
NastyL98_T/A's Avatar
Car: '88 T/A and '90 T/A
Engine: LB9/383
Transmission: T5/700R4
What he said.
I use permatex on all my head bolts too. And don't forget the RTV around the coolant jackets on teh intake manifold
Old Dec 20, 2003 | 10:32 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
That's exactly what I did the first time. I just wanted to make sure it was correct since I'm doing it again.
Bubbajones_ya
Jul 6, 2024 08:32 PM
Linson
Sep 21, 2015 01:08 PM
bamaboy0323
Sep 12, 2015 07:14 PM
hdis2002
Sep 8, 2015 02:52 PM
roysatikas
Sep 7, 2015 08:08 PM
