Engine swap and tpi
Old Dec 16, 2003 | 03:58 PM
cali92RS's Avatar
Car: White KSwisses
Engine: 5.3L Gen III
Engine swap and tpi
Alright, heres the deal.
Right now ive got the LO3. So im upgrading the chassis and suspension. In the not to distance future, i want to install the Scoggin-Dickey tpi crate engine, which comes wit a base.
My question, wheres a good place to get a complete TPI setup (minus the base)? I need everything(minus the base).
Thanks,
Ken
Old Dec 16, 2003 | 05:12 PM
cdartz's Avatar
You are going to end up buying a complete setup, and then simply sell the base. Your only other option is to buy everything seperately. Nobody is going to sell everything together except the intake base. If you decide to purchase items individually I have an extra set of runners I'd part with. They aren't perfect, so I'd sell them cheap.
Old Dec 16, 2003 | 06:24 PM
cali92RS's Avatar
Car: White KSwisses
Is the tpis setup a good piece?
It seems kinda pricey.
Ken
Old Dec 22, 2003 | 12:27 AM
zerotosixtyV8's Avatar
Car: Camaro
you will only gain about 20 HP from a full TPI swap on that L03, if that. IMO, get yourself a dual plane intake manifold and a 500 cfm carb, and pull a vaccuum advance distributor from a junkyard. you'd pick up 20 HP and some low end for a lot cheaper and easier than a TPI swap and need for computer tuning and a new fuel pump.
Old Dec 22, 2003 | 05:03 AM
cali92RS's Avatar
Car: White KSwisses
I wasnt going to change my LO3 to TPI, i was gonna put a TPI on the crate engine.
Ken
Old Dec 22, 2003 | 02:58 PM
Car: Camaro
do carb on a crate motor as well. unless you are planning on running "TPI" as in HSR, Miniram or LTRs, a TPI manifold will restrict you to power under 5700 rpm on a 350, under 5000 on a 383 and under 4500 on a 406.
Old Dec 22, 2003 | 03:45 PM
cali92RS's Avatar
Car: White KSwisses
Carb=fail emissions and visual inspection here in california.
Old Dec 22, 2003 | 04:00 PM
1bad91Z's Avatar
Car: Faster
Engine: Than
Transmission: You!
So will the TPI (visual inspection). Your car came with a TBI.
Plus, I dont think the vortec base has a C.A.R.B. sticker for California.
Old Dec 22, 2003 | 04:26 PM
Car: Camaro
oh my, I feel sorry for you mate
just get an LS1 lol
Frozer!!!
Jan 19, 2024 04:55 PM
camaro11j
Sep 19, 2018 08:49 AM
theshackle
Mar 5, 2017 06:37 PM
jharrison5
Aug 19, 2015 05:53 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
