Took the TPI to the track
Old Dec 18, 2003 | 08:47 PM
Kingtal0n's Avatar
Car: 5.3L turbo 2800lbs RWD
Transmission: 4l80e
Axle/Gears: 3.512
Since the transmission lost 3rd gear, and a Stealthram is going on along with a new converter and a rebuilt 700R4, i figured i would take it to the track and see what happens to it!
Well long story short, I pulled a 2.3 60' time, and Ran a 14.4 @ 93MPH in second gear with it locked up.
My 1/8 mile was 78MPH and 9.3 by the 1000 i was almost hitting the rev limiter and pulling a 12.08 shortly thereafter my 2nd gear ended and i just held onto it for the remainder of the track
I ran again and had tire spin; 2.8 60' 1/8 was 10.5@76 1/4 was 15.6@93MPH which is the end of 2nd gear of course.
I felt that if i could have shifted it would have pulled a 13 out of the hat on the first run. i also lost 4* of timing from false knock retard and a slipping tranny in first gear.
running super rich too; well it was fun!
now i replace suspension
rebuild tranny
3000 Sconverter
3.73 gears and posi
then we will see what happens with the TPI. then ill put in the solid roller and the stealthram and see what happens too;
then bolt on the D1-SC and crank up the boost and see what happens!
Old Dec 19, 2003 | 07:13 AM
vwdave's Avatar
KingTal0n, your in florida?
I would love to see/hear that beast run.
Old Dec 19, 2003 | 03:38 PM
N8MAN1068's Avatar
Car: 85 ta ws6 KITT
Engine: Lb9
Transmission: th350
sounds like me 2 years ago....lost 3rd gear, so i decided just to see how much abouse 1 and 2 could take.
A few 10.19's in the 1/8th, and it was a gonner.
there's just something satisfying about seeing exactly how much you can abuse your car before it breaks.:lala:
Old Dec 19, 2003 | 05:13 PM
Kingtal0n's Avatar
Transmission: 4l80e
Axle/Gears: 3.512
VW I live in miami too, In the cutler ridge area; I work at best buy cutler ridge. phone 786-306-3124 give me a call
deracer
Apr 11, 2016 12:04 AM
86White_T/A305
Aug 17, 2015 12:16 AM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
Feffman
Aug 13, 2015 07:11 AM
Sanjay
Aug 12, 2015 03:41 PM
