need help picking out a cam
Old Dec 30, 2003 | 03:01 PM
1badrocZ's Avatar
Car: 1985 IrocZ
Engine: Carbed 383
Transmission: Tremec T-56
hey, i have a 1985 305 TPI that has a few things done but not much and i am looking at getting a cam for it. Im just not sure what i need or what would work the best for my car. Any help is appreciated, thanks.
Old Dec 30, 2003 | 03:27 PM
Insomniac92z28's Avatar
Car: 92Z28
Transmission: A4
I here the LT1 cams work pretty good in the 305 tpis and they are cheap.
Old Dec 30, 2003 | 03:57 PM
N8MAN1068's Avatar
Car: 85 ta ws6 KITT
Engine: Lb9
Transmission: th350
lt1 cam won't work in the 85...it's not hyd. roller..
i'm looking at going with either a elgin e1015: .465" intake lift, .488 exhaust lift Dur. @ .050 224 degrees intake, 234 degrees exhaust 112 lobe center
or Comp nitrous hp: dur. @ 0.05 224 int., 234 exh, .477/.490 113lsa
in my 85 ta
Old Dec 30, 2003 | 04:01 PM
Car: 92Z28
Transmission: A4
I'm an idiot. What he said.....
Old Dec 30, 2003 | 05:15 PM
1badrocZ's Avatar
Car: 1985 IrocZ
Engine: Carbed 383
hey n8man, will either of those work on a pretty much stock 85 305 tpi motor? and where can i get one at?
Old Dec 31, 2003 | 04:58 PM
1badrocZ's Avatar
Car: 1985 IrocZ
Engine: Carbed 383
does either of these cams sound good for my setup?
crane cam for low end and mid range
Duration: 254º/264º
Gross Lift: .401''/.423''
series : 2030
crane cam for mid range and top end
Duration: 264º/274º
Gross Lift: .423''/.446''
series : 2040
Old Jan 1, 2004 | 03:39 PM
Roostmeyer's Avatar
Car: 88 Trans Am GTA
Engine: 5.1L Gen III
Axle/Gears: 3.70
I think I found the cam your looking at the emission legal cams or at least thats the only cams crane makes with those lift numbers. the first one looks about like a stock peanut cam. The second one looks like a stock non-peanut cam. Advertised duration tends to have to many variables to be accurate. For the most part people tend to look at .05 duration #'s. I'd look for something close to or under 210 intake duration and around 218 exhaust duration. You may want a cam ground on 112 LSA that won't lope as much as one ground on 110 also.
N8MAN1068 that cam will probably be way too big for a 305 unless you plan to really rev the **** out of it. Remember that roller cams peak earlier than flat tappet cams.
Old Jan 2, 2004 | 01:20 PM
N8MAN1068's Avatar
Car: 85 ta ws6 KITT
Engine: Lb9
Transmission: th350
1bad, i'm probably the worst person to ask about which cams to run.
I get my info from sharing DD2000 cam files and running them with my setup, and from asking here and cam companies.
Most people here are saying that the cam i mentioned is too big for a 305. I guess it all depends on what you want to do with your engine, how you drive, what parts you're upgrading .
Would I get a larger cam and stick it in an other wise stock engine? no. I'm running the full gammut of heads/intake/headers, stall and cam, and still won't know how the 305 handles it until it's all put together later this summer.
Old Jan 2, 2004 | 02:11 PM
Fevre's Avatar
Car: 89 Formula
Engine: 355
Here is a cam I am running right now in a 383 stroker:
Specifications:
* Advertised duration: 272 intake/282 exhaust
* Duration at .050 in. cam lift: 214 intake/224 exhaust
* Gross valve lift: .442 in. intake/.465 in. exhaust
* Lobe separation: 112 degrees
* RPM range: 2,000 to 4,500
* Good idle quality
http://store.summitracing.com/partde...2DK1103&view=1
I think it would be a good cam to run with a 305 and pretty much stock TPI.
Here is a whole kit but smaller cam:
http://store.summitracing.com/partde...2DG5000&view=1
Old Jan 2, 2004 | 02:54 PM
NufNuffZ28's Avatar
Car: 1987 Iroc
Engine: 357 Single plane and a Ysi vortech
Axle/Gears: 3.50 9"
In my car 86 TPI I ran a crane cam from JEGS with great results. It was 440/454 lift and can not remember the duration. WORKED GREAT. Look in Jegs under their Crane cam section. Ran 9 flat in the 1/8'' with just that and Edelbrock shorties
Chris
Old Jan 3, 2004 | 06:47 PM
1badrocZ's Avatar
Car: 1985 IrocZ
Engine: Carbed 383
does something like this sound good?
Advertised Duration: 266º
Duration @ .050: 210°
Lobe Separation: 110°
Gross Lift: .440''
RPM Range: 1600-4600
Fevre im a little nervous running a summit brand cam in my car. I would rather go with comp or crane, if somebody could help my find one that would be great! thanks
junkcltr
Aug 2, 2019 11:12 PM
Street Lethal
Apr 30, 2019 12:14 PM
Below Average J
Members Camaros
23
Nov 18, 2015 10:03 PM
camaro71633
Sep 1, 2015 10:24 AM
Fronzizzle
Aug 9, 2015 01:15 PM
