Siamesed Runners
Car: 1986 Pontiac Trans Am
Engine: 5.0 TPI
Siamesed Runners
Those siamesed runners....are they really worth getting for a 305 TPI with the mods listed in my sig? Just curious what I should expect from them if anything. On a side note, I'm putting the Hooker 2055's on relatively soon as well.
Car: 1990 Firebird Formula 305
Engine: 305tpi w/145,000 on the clock
GM High Tech magazine just put some on their 305tpi 5 speed and got like 5hp and 7ft/lbs but it was all the way across the band. You may get more because of your cam, but not much. If the base is ported or aftermarket it is well more worth it. I found my runners in the classifieds for 125 shipped. Check the listings. I always see them there for less than 200. This makes it a little more worth it as well.
Engine: 5.0 TPI
Engine: 5.0 TPI
I would do it. 5 RWHP throughout the powerband is great! Like others have said - don't focus on "peak power", focus on "average power".
Car: NCC-1701-D (docked in AZ)
Engine: impulse drive
Transmission: fusion reactors
Axle/Gears: Rescued from the Borg by my crew
Originally posted by PhantomTPI
There is just a couple things left I need to know about these runners. First, someone on this board is selling them for $200 i believe(I forgot the username)....but he's advertising the runners WITHOUT cold start valve. What exactly does that mean? I believe my car has a cold start valve....so these runners would be for a car WITHOUT a cold start valve? Second, to install these, its relatively easy, right? Can do one side at a time, take the old one off, put the new one on? Bolt-on? Thanks everyone.
200 is a fair price for siamesed runners if their SLP's. Not for stock ones tho. If your system has a 9th injector you can use the runners if they have the opening for it. Otherwise you cant. You will need runners from year 85-88 only. After that the cold start injector was eliminated. You should be able to remove one side at a time. You will probably need new gaskets as well. Siamesed runners will help you some if they are siamesed approx 2 inches. This theoretically "shortens" the runner length as far as air flow is concerned.
Just noticed this is my 100th post!! I am a senior member now. Wahoo! Does this mean I am an old man? Do I get any "senior" discounts from board sponsors?
Engine: 5.0 TPI
I think you mean cold sart injector?
...will have to look around more... Supreme Member
Car: 1990 Iroc-Z
I think you can elminate your cold start injector. I'm not sure, but I believe the prom can be edited to delete the function and the injector nook can be plugged or whatnot.
Don't despair until you verify that there is no way.
Engine: 5.0 TPI
Engine: 5.0 TPI
yes i meant the runners are for cars without the cold start valve.
There you are....yea, unfortunetly, my car has the cold start valve. I'm assuming these runners are available somewhere for cars with the cold start injector?
Engine: 5.0 TPI
yes SLP makes a set with the hole for the CSI. but i'm also guessing ppl have deleted theirs without any problems. mine dont have one so i dunno how the car would run cold without a CSI.
Car: GM & Jaguar
Engine: Various
Transmission: Various
Axle/Gears: Various
Sounds like you're getting answers, but here's what I understand;
As far as the CSI is concerned, it can easily be eliminated. Accel makes a kit to do so in fact (mrgasket.com). For the runners, based on the flow characteristics, they will have a lower flow VELOCITY on the bottom end, what that means is you'll be sacrificing torque. If you've got a fair amount of "lump" in your cam then the increased VOLUME they flow on the top end will compliment it wonderfully. So it comes to what you want the car to do - pull hard or scream top end. I think a good comprimise would be large tube runners; I think they maintain velocity a little better on the bottom end, yet out-flow original ones by FAR on top, but won't flow like the siamesed guys.
Any corrections, anyone? Please let me know if I'm off base here
Engine: 5.0 TPI
Car: GM & Jaguar
Engine: Various
Axle/Gears: Various
Then your best bet is to get with a pair with larger tubes, or simply modify your existing ones because of the cam you've got and it is a 305. I just did a little gasket matching with the entire TPI system (TB, Plenum, Runners, Intake Base) on my 305. It suffered out of the hole because of my cam, but was pretty nuts on the top end - my cam was too lumpy so it was a bit mismatched, but it pulled STRONG between 2800 and 5500+ for such a small motor. That's my advice, I doubt you'd be happy with the siamesed with a cam like that in a 305.
EDIT; Not much driving over 110mph? C'mon man! That's where the fun starts! The fastest I took mine up to was 147mph... then I ran out of road
- I had to use a "speed calculator" on my PC and input my rpm, tire size, gear ratios, etc. because my speedo doesn't go that high!
- I had to use a "speed calculator" on my PC and input my rpm, tire size, gear ratios, etc. because my speedo doesn't go that high! Last edited by tpiroc; Jan 5, 2004 at 03:24 PM.
Engine: 5.0 TPI
Car: GM & Jaguar
Engine: Various
Axle/Gears: Various
It's not specified WHERE the GM Tech car made those gains. In fact, since it's noted that the 7ft/lb came "all the way across the band" means it eventually did buzzed up high enough to flow - NOT throughout the band - by the time you even thouch that measly 7ft/lb of torque, you're out of the hole, and about where your cam falls flat. 90form305tpi posted that comment about it working well with your cam before you stated it was for an idle-4k powerband; a lot of people misunderstand cam degree specs and what kind of power it makes and where.
Engine: 5.0 TPI
Car: Faster
Engine: Than
Transmission: You!
TPIS or Arizona Speed and Marine sells large tube runners. Look to pay out the wazoo for them though!
If I were you, I would just get the SLP's. Then remove the Cold start injector and cap off fuel rail. Then use a PROM/Memcal from and 89 IROC and you will notice a performance increase.
Then port-match your plenum and runners to a set of TPIS big-mouth gaskets for a little more power.
But, that's just what I would do...........
Engine: 5.0 TPI
Royal_Z
Sep 30, 2015 08:45 PM
