Intermittent 305TPI fuel/ignition system problem...Need help quick...
Old Jan 2, 2004 | 02:06 AM
HM Murdock's Avatar
Car: 1988 Formula and 1995 LT4 Z28
Engine: 305 TPI and 361 LT4
Transmission: M5 and stalled A4
Hey all, I need some help pretty bad on my 88 305 TPI M5...It has an intermittent problem with the iginition or fuel system that causes it not to be able to rev above 3K, shake hard above 2K, and have a massive power loss...It feels and smells like a fuel issue, since it smells very rich...I checked my coil and plug wires for spark, I am getting it..When it happens, it will not go away, it does it in every gear, neutral, and with clutch depressed or open. If I turn off the car for about 1 minute, it goes away for a while, but will return. It does flash an SES light solid, but I don't have my Chilton's with me, which ALDL connectors do I jump to get the code? An ideas on how to fix the car would be hot, too.
TIA...
Old Jan 2, 2004 | 04:11 AM
HM Murdock's Avatar
Well, it looks like it was just bad gas...from 2 different gas stations...Never had that problem. I finished off most of te current tank and put in 5 bucks worth, and it was fine. The odd thing is the last 2 places I went I have been to many times, even with the Z28...Never had any problems before, and they are name brand. Odd.
Veaceonee
Sep 29, 2016 08:15 PM
Grant2k
Apr 4, 2016 08:21 AM
BWilcox
Sep 20, 2015 12:19 PM
TrevinE
Sep 14, 2015 03:20 PM
scottmoyer
Sep 7, 2015 07:06 PM
