Swapping tpi to lt4
Swapping tpi to lt4
I was wondering if this is possible. I got a 92 GTA w/ a 350 tpi L98 engine. Summit has this kit to convert your lt1 to lt4, it comes with the heads, cam, and intake. I was wondering if this can hook up on to my block or is there no chance in hell this will happen? Thanx for your replys.
Peace Out,
PsychoGTA
Peace Out,
PsychoGTA
Car: 1997 Jeep Wrangler
Engine: 4.0L
Transmission: 5 speed
Axle/Gears: 8.8 rear, 4.56 gears, 4:1 transfer
Yes you can. To do this you would need to modify the heads quite a bit including welding. Here's a couple links on the LT1/4 head conversion to SBC.
http://www.lt1intake.com/LT1_retrofit.htm
https://www.thirdgen.org/techbb2/sho...hreadid=178262
Then the intake would require a distributor hole to be located and machined. No coolant fittings or bolt pattern mods would be required since it will bolt up to the orginal heads.
Engine: 4.0L
Originally posted by zerotosixtyV8
LT4s are for use with Vortec heads, an LT1 intake is what you'd want for a standard SBC head
LT1 intakes can be used of course on LT1 heads or standard (early or late) SBC heads (intake modifications required).
The only intake that will fit Vortec heads is an intake specificly designed for it.
Car: 92' RS
Engine: 357
Transmission: TH350
Axle/Gears: 4.10
I dont know why but i always had the impression that lt4 heads and lt4 vettes were DOHC. But reading around for the last year i have understood that isnt right. What motor and heads were
32v DOHC? Whats the engine code? The ZR1 was a DOHC right? What about the 96' Grand Sport?
Engine: 4.0L
fast burns use vortec bolt patterns though
But.........Fastburns have standard SBC intake ports...........Vortecs do not.
Originally posted by John Millican
Correct, Fastburns use standard SBC and Vortec bolt patterns.
Car: '89 GTA
Engine: a bunch of pieces
Transmission: still there - very stockish TH700
LT4's are only for LT4 heads or Fastburn heads (intake modifications required).
I'm asking because this combination of parts looks like low $$$ powerful combo for us, FI guys, only comparable to LT1 heads/int. (and you don't have to modify deck surface...)
What is the final answer, then? to go or not to go with Vortecs?
Car: Faster
Engine: Than
Transmission: You!
Actually, the fast-burn heads do have the taller ports (just like the vortecs AND LT-4's).
Why do you think the mini-ram III, ram-jet, AND SDPC TPI base will work with vortec and fast-burn heads?
Answer, because the ports and bolt-patterns are the same.
In theory, the LT-4 intake can be modified to work with vortec/fastburn heads and an old-school SBC (modify intake for distrib. hole and water passages, etc....) which is alot easier than modifying the LT-4 heads to work with an old-school SBC, but even that can be done.
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
when it comes down to it, unless you're doing the machine work yourself, it isnt cost effective. get heads that fit the SBC.
the vortech and fast burns have the same ports and bolt pattern. ive been told the LT4s also match em, but ive never seen it in person, so i cant confirm that.
LT1 intakes have the same pattern and ports as a SBC, so with a lil machining for a distrib hole, and the addition of a remote thermostat, it fits.
1988iroc350tpi
Aug 14, 2015 07:52 PM
Sanjay
Aug 12, 2015 03:41 PM
