Need Fuel Injector Help - ASAP!!!!
Old Jan 6, 2004 | 01:42 PM
EYEROCK89's Avatar
Car: 1989 IROC
Engine: 5.7 / 350 cuid
Can someone please tell me quickly if these look like they will work on my 89 5.7TPI IROC with stock FPR?
http://cgi.ebay.com/ebaymotors/ws/eB...tem=2452734459
Old Jan 6, 2004 | 01:48 PM
Chupakabra-King's Avatar
Car: 1989 Firebird Formula
Engine: 305 TBI
Axle/Gears: 3.08
Well , they will WORK , but , you are gonna run rich until you tune it . An AFPR would help until you could get a tune on it ........
Old Jan 6, 2004 | 01:51 PM
bnoon's Avatar
Car: 2008.5 Mazdaspeed 3 GT
Engine: 2.3 DISI Turbo
Transmission: 6 speed MT
Since that's a set of four, you would need four more exactly like it for ECU tuning to do any good. Stock injectors are 22# and 19# for 350 and 305's.
Old Jan 6, 2004 | 02:59 PM
Engine: 305 TBI
Axle/Gears: 3.08
bnoon , you are right , I didnt see that there were only 4 . So thats $200 bucks for a set of injectors . Eyerock , if you want 24#ers , why don't you go to SLP's website and get their 24#ers ? They are $99 for 8 of them .......
Old Jan 6, 2004 | 06:13 PM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
I will never buy anything from ebay, you never know what you are getting. Call a motorsports shop that you trust and buy stuff from them.
Old Jan 7, 2004 | 12:57 AM
TKOPerformance's Avatar
Car: '86 Camaro, '02 WRX, '87 K5, '67
Engine: 350 TPI, 2.0turbo, 383 in the works, 289-4BBL, 232, A-head 4-cylinder
Transmission: T56, 5-speed, 700R4, C4, T176, semi-auto 2-speed
Axle/Gears: 3.73, 3.90, 4.88, 3.55, 3.54, 7.00
I'm running 24 lbs/hr injectors from SVO (Ford Motorsports) that I bought through Summit for $225. I had TPIS burn me a chip to compensate for the different fueling characteristics of the larger than stock injectors. There isn't enough adjustability in an adjustable FP regulator to get them to run right, and even then you'd be decreasing fuel pressure, which is never a good thing because it hurts the spray pattern and atomization.
The completed setup runs great.
Old Jan 7, 2004 | 02:31 PM
EYEROCK89's Avatar
Car: 1989 IROC
Sorry, I sent the wrong link. I was looking at a set of 8. Crap, I was hoping the injectors would be cut and paste. If I get an adjustable FPR...will I still need to get the PROM burned?
Old Jan 8, 2004 | 07:38 AM
Engine: 305 TBI
Axle/Gears: 3.08
Yep , you sure will ............
Old Jan 8, 2004 | 07:49 PM
Captain C's Avatar
Car: 1985 IROC-Z
Engine: 1989 350 4 bolt roller block
Transmission: ProBuilt 700R4 Road Race with Edge 9.5" 2800 stall lockup converter
I'm running 24# injectors with a stock FPR (have used an AFPR as well) I have never had a problem with my 85 or 89 computer using them. I do have a problem with it when the weather is really cold. It actually acts like it needs to be richer. Acts like a carb with no choke. Calibration on the chip more than anything......
Old Jan 9, 2004 | 10:06 PM
89ReDIrOcZ's Avatar
Car: 1989 Camaro Iroc-Z
Engine: 5.7L 350 TPI
Transmission: 700r4, Shift Kit
Captain C
sup u live in bakers. CA.??? i live just around the block from u in wasco.
BTW, is ur name rich? and did u used to post on the bakersfieldstreetracing forum a while ago??? if so im GCSIROC on there i hit u up a few times i think .
bryan623
Mar 22, 2021 06:43 PM
New2Chevy
Oct 4, 2015 11:27 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
kyleb24
Aug 15, 2015 08:24 AM
Firechicken86
Aug 12, 2015 10:07 PM
