TPI Idle Problem
Old Jan 12, 2004 | 11:27 PM
Hoss50's Avatar
Car: 1985 K5 Blazer
Engine: 350 crate w/TPI MAF
Transmission: 700R4/NP208
TPI Idle Problem
I got my TPI running yesterday. (swapped 88 MAF TPI onto my old carbed 350). Now I am trying to tune it and get it running well. I am having a problem with my idle. Once the motor runs for a little while (1-2 minutes) the idle gets real erratic. It dips, picks up, dips picks up, etc. The more it runs the worse the idle gets. It will eventually stall out.
I reset the TPS. It was at .570 volts and I set it to .508 volts.
My 0xygen sensor is not installed right now. Would this do it or contribute?
Also though if I rev the motor up (say 3K) and hold the throttle there the RPM will stay for a few seconds then drop down (2K) and pop up some and drop again, etc.
I am thinking my TPS might be bad but I don't know.
No codes are set though. (beside 12) and the check engine light doesn't appear while the motor is on.
Old Jan 13, 2004 | 01:50 AM
TKOPerformance's Avatar
Car: '86 Camaro, '02 WRX, '87 K5, '67
Engine: 350 TPI, 2.0turbo, 383 in the works, 289-4BBL, 232, A-head 4-cylinder
Transmission: T56, 5-speed, 700R4, C4, T176, semi-auto 2-speed
Axle/Gears: 3.73, 3.90, 4.88, 3.55, 3.54, 7.00
Not having the O2 sensor hooked up wouldn't cause a problem like this. The ECM isn't even taking a reading from it until the car is fully warned up.
Sounds like a vaccum leak problem. I'd go over all the lines and connections. A good trick is to spray them with carb cleaner. If the idle races then you've found a leak.
If there isn't a vaccum leak then I'd suspect the IAC. You can adjust the IAC steps by turning the throttle stop screw clockwise. There may be a plug over the set screw. Just remove it and you can access the screw. Adjust in 1/2 turn increments. You'll have to reset the TPS voltage after each adjustment.
Infested
May 22, 2018 11:56 PM
Wade787b
Sep 29, 2015 01:15 PM
db057
Aug 22, 2015 08:17 PM
Sanjay
Aug 12, 2015 03:41 PM
