It turns over...and over...and over...
Old Jan 11, 2004 | 07:49 PM
redrummer's Avatar
Car: '88 Trans Am GTA
Engine: 5.7L L98
Axle/Gears: 3.27 Aussie 9 Bolt
Problem:
The car just turns over, and over, and over. Every once in a blue moon, it'll fire up and run with no problem. Last time it did, I took it for a test drive around the neighborhood and when I got home, shut it off and had to push it back into the garage because it wouldn't fire again. I'm getting spark to my distributor cap, but not past it. I'm also getting fuel, so no problem there.
What's been done:
Replaced the coil (old one was dead).
Replaced pickup coil (twice).
Replaced ignition module.
New cap.
New rotor.
New spark controller.
Checked for 12v at pink wire on coil. Good.
Checked for continuity in two-wire connector going from coil to distributor. Good.
Tested pickup coil. Good.
Cleaned and rebuilt distributor.
I'm at a loss. Could my VATS be playing with me? Everywhere I've read says that the starter shouldn't even turn when the VATS goes out, but that's not what's happening to me. I'm just getting no spark. I'm also getting no codes except for the MAF code, but the MAF tests out fine, so I'm counting that as just "one of those things".
Any ideas? Anyone?
Old Jan 11, 2004 | 08:04 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
If you're getting spark to the distributor and you're getting fuel, then it is not a VAT's related issue. Have you checked the MAF sensor relay or the MAF burn-off relay since you are getting a MAF trouble code. Also, have you checked the electronic spark control (ESC) module? Just a thought!!!!!!!!!
The Trickster!!!!!!!!!!
Old Jan 11, 2004 | 08:11 PM
redrummer's Avatar
Engine: 5.7L L98
The ESC is pretty much brand new. I've also tried replacing it with one out of a friend's car and the same thing happens.
Both MAF relays are still pretty much brand new too. I've also replaced them with known working ones.
Old Jan 11, 2004 | 09:02 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
If you would like it, I have a troubleshooting chart from the GM service manual for the ignition system that I can e-mail you. It might be able to help some with your problem.
The Tricskter!!!!!!!!!!!
Old Jan 11, 2004 | 09:38 PM
MR. KIDD's Avatar
Car: 85 IROC
Engine: 406
Transmission: A4
Just a thought, is the ecm pulseing the injectors I have had computer work everything else and not turn the injectors on.
Old Jan 12, 2004 | 04:49 AM
redrummer's Avatar
Engine: 5.7L L98
Sure, couldn't hurt. I have a feeling it's the "crank but no start" copy I already have, but send it anyway. lilcodger@alltel.net
Fuel system's working fine. I've hooked noids up to all injector harnesses and they're all firing. Just to be sure, I lifted the fuel rail and watched for spray as a friend cranked it and they were all spraying.
Old Jan 12, 2004 | 09:00 AM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Sorry Redrummer,
When you mentioned about the copy you already had, I did some checking and found that I had already sent you a copy of it previously. I will do a little more checking and see what I can find for you.
The Trickster!!!!!!!!!!!!
Old Jan 12, 2004 | 07:53 PM
redrummer's Avatar
Engine: 5.7L L98
Oh, that's right. It was you!
I knew that...
Old Jan 12, 2004 | 08:30 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Hey Redrummer,
How about e-mailing me with the specifics of your problem and what you have done on it to date to correct the problem and see if between us and the others we can't get your car running and purring.
Old Jan 12, 2004 | 08:44 PM
MR. KIDD's Avatar
Car: 85 IROC
Engine: 406
Transmission: A4
Just another thought does your tach work had one once the tach went bad and grounded the ignition out.
Old Jan 13, 2004 | 04:48 AM
redrummer's Avatar
Engine: 5.7L L98
MR. KIDD,
The tach works.
Trickster,
I'll write it up tonight after I get back home.
gta892000
Aug 11, 2019 11:16 AM
83 Crossfire TA
Jan 3, 2016 01:26 PM
bbsr72
Sep 27, 2015 05:55 AM
greenyone
Sep 8, 2015 08:41 PM
83 Crossfire TA
Sep 8, 2015 12:06 PM
