Idle/stumble problem
Old Jan 14, 2004 | 06:16 PM
Hoss50's Avatar
Car: 1985 K5 Blazer
Engine: 350 crate w/TPI MAF
Transmission: 700R4/NP208
I went and fired my truck up after getting the TPI installed and I am having stumbles off idle and it is just running like crap.
So I tried disconnecting the MAF sensor and my idle got better and my stumble has been eliminated. Does this mean my MAF is bad? I am just running a cone K&N on the end of my MAF right now, but it does it with or without the filter installed. Thanks
Harley
P.S. The truck is an 85 K5 Blazer with 350 that I converted to 88 MAF TPI from a Firebird.
Old Jan 14, 2004 | 07:47 PM
BLACK ICE's Avatar
Car: 91 RS
Axle/Gears: 10 bolt
It sounds to me like you have a bad MAF sensor do you have the ALDL under the dash? if so it should read a code 34 if it does replace the maf sensor. that should be it.
Old Jan 15, 2004 | 01:38 PM
TKOPerformance's Avatar
Car: '86 Camaro, '02 WRX, '87 K5, '67
Engine: 350 TPI, 2.0turbo, 383 in the works, 289-4BBL, 232, A-head 4-cylinder
Transmission: T56, 5-speed, 700R4, C4, T176, semi-auto 2-speed
Axle/Gears: 3.73, 3.90, 4.88, 3.55, 3.54, 7.00
Nice truck. I've got an '87 K5.
Sounds like a bad MAF to me. Check for codes as mentioned.
Old Jan 15, 2004 | 02:23 PM
BLACK ICE's Avatar
Car: 91 RS
Axle/Gears: 10 bolt
Man TKOperformace you got alot of cars!
Old Jan 15, 2004 | 02:46 PM
Oh, and that's just the stuff I listed. It doesn't count the 1917 Model T Ford truck I've got that I'm waiting to sell. I also had a '74 Nova SS that I'm mostly finished parting out, but the shell is still taking up space in my garage. My old 5.0 Mustang is still around too. I sold it to my brother, but he hasn't done anything with it, so at this point I think it's as much mine as it is his, given all the work I put into it before the motor went south.
I am a recovering autoaholic. I haven't bought a new vehicle in about two years, but I'm still just taking it one day at a time.
pjsparts
Oct 29, 2025 06:39 PM
88rscamar0
Sep 23, 2015 09:08 PM
Ranbo108
Sep 9, 2015 12:20 PM
383cam
Sep 9, 2015 06:01 AM
andy74
Sep 3, 2015 08:41 AM
