Wanted-totally stock 350 TPI for testing LT1 intake
Old Jan 16, 2004 | 07:32 PM
John Millican's Avatar
Car: 1997 Jeep Wrangler
Engine: 4.0L
Transmission: 5 speed
Axle/Gears: 8.8 rear, 4.56 gears, 4:1 transfer
I am actively looking for someone that has a totally stock 350 TPI engine that is willing and able to dyno it for a baseline. I will provide a LT1 intake conversion for the volunteer to install and do a final dyno testing. Results will become my property (orginal dyno slips, before and after) and I will let the volunteer KEEP the intake.
The volunteer will be required to provide everything but the LT1 intake and fuel rails which I will provide. In other words he will be required to provide his own remote t-stat housing and plumb his own fuel lines. I will only provide the intake and fuel rails.
Volunteer must be able to prove good intentions on carrying out the contract. Parts will be provided in good faith, no upfront charges or holds on credit cards. I reserve the right to select the volunteer or deny them all based on feedback.
john@lt1intake.com
Old Jan 16, 2004 | 08:40 PM
JERRYWHO's Avatar
John
Sounds like a fun test.
I can offer you my car it is a 92 350 auto has only two things done to the motor SLP headers with factory cats and a Edelbrock base with stock runners on it. I can get Dyno numbers and have track times on it. One other thing I can do is a test with the stock AUJP and then a few runs and see what I can do with the Bin just for the intake.
Jerry
Old Jan 17, 2004 | 03:27 AM
85IrocNOH's Avatar
Car: 85 Iroc-Z
Axle/Gears: 10-bolt 3.42
How about a bone-stock 305?
I need something to put in this big gaping hole under the hood and i've been considering an LT1 intake whether i stick the 305 back in or get a 350.
Old Jan 17, 2004 | 08:52 AM
Engine: 4.0L
Originally posted by JERRYWHO
John
Jerry
I put you on my list Jerry. I will accept headers. I know the Edelbrock base isn't doing to much since your runners are still stock.
BTW Jerry, you were right about the RF noise and my Datamaster scans. The MSD filter fixed it.
Old Jan 17, 2004 | 08:55 AM
Engine: 4.0L
I will do the same for a 305 at a later date.
I would require you to do a dyno run before for a baseline so the "gaping hole" would have to be filled with a stock TPI first.
Old Jan 17, 2004 | 10:14 AM
89BlueIROCZ28's Avatar
LT1 test
I have an 89 IROC 350 TPI 700R4 2:77 bone sstock except for Hedman ceramic coated long tube headers. I would love to see the performance difference!
Old Jan 17, 2004 | 10:23 AM
1bdbrd's Avatar
Car: 1991 Trans Am
i have a 1991 trans am with the L98 in it. already have close to stock baseline numbers. i have hedman shorties on the way with a carsound cat but i can install them, do another baseline and then if you want me to, i will install the intake and get another set of numbers.
i have a shop close by that i can do dynoing at. it might also be interesting to dyno 2 L98 cars, one a MAF car and one a SD car just to see the differences. or even a camaro and a firebird and see the differences in intake routing.
Old Jan 17, 2004 | 10:56 AM
TKOPerformance's Avatar
Car: '86 Camaro, '02 WRX, '87 K5, '67
Engine: 350 TPI, 2.0turbo, 383 in the works, 289-4BBL, 232, A-head 4-cylinder
Transmission: T56, 5-speed, 700R4, C4, T176, semi-auto 2-speed
Axle/Gears: 3.73, 3.90, 4.88, 3.55, 3.54, 7.00
I've got an '86 IROC Z28 with a stock TPI setup. The car is still an MAF system. The trans is a T56. The rear is a 10-bolt with 3.73s.
The engine has Edelbrock TES headers, deleted AIR system, 24 lbs/hr. Ford SVO injectors, a serpentine beltdrive conversion, and an adjustable fule pressure regulator. The exhaust is a Edelbrock Y-pipe, a gutted cat, a stock mid pipe, and a Dynomax muffler and tailpipes. I have a custom TPIS PROM.
The only downside to the "stock" situation, aside from what I've already mentioned, is that the engine (originally a 305) has been replaced with a Goodwrench 350. I know that the early TPI motors had small, non-roller cams anyway, but I don't know if this will blow the "stock" situation out of the water.
There is a chassis dyno place close to my house where I could do baseline and modified testing. Plus, I live reasonably close to Cecil County Dragway, where I drag race occassionally. It would be a nice addition to do back to back track testing too. Let me know what you think.
Old Jan 17, 2004 | 12:58 PM
Engine: 4.0L
You're on the list TKO.
I have said I will allow headers. I also condier a Goodwrench engine "stock".
Old Jan 17, 2004 | 01:16 PM
Cool. Let me know if I win. I'd love to work with you on this project.
Old Jan 17, 2004 | 02:32 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Lol...only a few posted replies...bet you have a few hundred emails, huh?
I'd do it in a heartbeat if Ca. would let me keep the intake on for emissions.
Old Jan 17, 2004 | 08:07 PM
SLP-GTA's Avatar
Car: 1991 Formula (sold)
cool tread, nice job John with
marketing the LT1 manifold for the L98. Its a very nice option and I'd think real world dyno numbers would really help you sell more LT1 conversion.
keep us updated
Old Jan 17, 2004 | 08:11 PM
89Formula5.7's Avatar
Car: 89 Formula 350
Engine: L98 w/ Stealthram
Axle/Gears: 9 bolt 3.27
I sent you a PM on SE3GO.
Old Jan 17, 2004 | 09:02 PM
Engine: 4.0L
I believe I have the primary volunteer identified already. You wouldn't believe the responses I've got for this project.
Old Jan 18, 2004 | 06:38 PM
TPIMarow6.6's Avatar
Car: 85 Camaro Z-28
Engine: 6.6
Transmission: 5-speed
John make sure to deffinately fill us in on the turnout, ill most likely be purchasing one of your intakes fairly soon!keep up the awsome work!
Old Jan 21, 2004 | 10:16 AM
Engine: 4.0L
Funny, you are so wrong. Sorry to say that yes, there were only a few replies to this offer and no, I did not receive hundreds of e-mail, not even dozens of e-mail. I only received a FEW e-mails.
Only one stood out from the rest because of his experience, knowledge, ability and access to test equipment to carry out this project. His name is Tom Krapf (TKOPerformance). Congratulations Tom.
Old Jan 21, 2004 | 10:25 AM
Thanks John. Good to hear. I look forward to working on this project with you.
Old Jan 21, 2004 | 11:31 AM
Z-PDX's Avatar
Car: '91 Corvette, Chevy-powered CJ-7, Dodge 2500 4x4
Engine: 5.7L - pretty stock
Transmission: 6-speed
John -
Thank you, thank you, thank you.
I have been following this forum for a long time, but never registered.... until now!
Like many TPI owners, I have been looking to change my intake.
But as you all know, there is so much marketing crap and unsubstantiated claims running around the auto industry. (I have worked in the auto industry for years, so its OK to take a couple swipes)
I want to applaud your efforts to bring some science and good intent to the auto aftermarket. Let's hope its the start of a trend.
If results are positive, you definitely have a customer here.
I would also be interested in seeing a step-by-step dyno tracking of L98 mods. i.e. LT1 intake, then common cams changes (ZZ4, HOT cam, 219 cam), etc...
Looking forward to results,
-Z
Old Jan 21, 2004 | 05:02 PM
bnoon's Avatar
Car: 2008.5 Mazdaspeed 3 GT
Engine: 2.3 DISI Turbo
Transmission: 6 speed MT
I plan on getting before and after dynos this spring for my 305, but I'm not quite stock either. Budget minded mods are going on at the same time too though, so any before testing mods may be negated by the new mods.
Cam swap (something similar to ZZ4, hot cam, SLP cam, etc), torque converter stall up to 24-2600, custom CAI and filter will all be on at the time of the LT1 swap.
I already have my LT1 intake, rails, etc and will be adding headers at the time of the engine swap. I'll provide you with all before/after dyno pulls for sending me a machined distributor adapter. Everything else will be accomplished *in house*.
Seems to fit right in to your "later date" time schedule. The Midwest gathering in June is when I had planned on dynoing the new combination. I have a few questions I'd like to ask if you're interested in this *almost stock* vehicle. Email me at bnmotorsports@msn.com if you have anything to ask me.
Old Jan 22, 2004 | 10:53 AM
N8MAN1068's Avatar
Car: 85 ta ws6 KITT
Engine: Lb9
Transmission: th350
i'd love to see a stock 305 w/lt1 intake
i'd offer mine, but mine isn't really 'stock' per se any more..., and i just sold my tpi setup to bank for a lt1 intake. lol.
Old Jan 22, 2004 | 10:57 AM
Dustin Imports's Avatar
Car: 1988 Medium Orange Metallic IROC
Transmission: 700R4 transgo shift kit
Axle/Gears: 4.10 in box lol
I ahve a bone stock l98 700 r4 89 IROC, stock exaust, manifolds, filters. everything.
let me know
Drew
roo5ter@hotmail.com
EDIT: i see you have your guinea pig
Old Jan 22, 2004 | 01:26 PM
SweetS10v8's Avatar
Car: '89 Formula 350 & '86 Z28
Engine: L98 & 355ci
Transmission: 700r4 in both
Add me to the list. I have a STONE stock L98 that still runs 14.25@95, has been well kept and would be perfect for this.
The dyno is 20 miles from here. I have wanted an excuse to dyno it 100% stock.
Edit: Im too late But if you decide on a TOTALLY stock one, Im always avaliable
Attached Thumbnails Wanted-totally stock 350 TPI for testing LT1 intake-sdfasdf1111.jpg
Old May 5, 2004 | 01:28 PM
OneBadZ4U's Avatar
Car: '86 Iroc, '87 Iroc Vert
Engine: 350 TPI, 305 TPI
Transmission: T5 in both
Axle/Gears: 3.73, 3.45 both LSD's
Is there any news on the Dyno numbers yet??
Old May 5, 2004 | 10:29 PM
Car: 85 Camaro Z-28
Engine: 6.6
yeah im interested too! im ready to put mine on...maybe i should find out for myself
Old May 6, 2004 | 12:28 AM
CrazyHawaiian's Avatar
Car: too many ...
If I was in the area I would volunteer. My 89 IROC is a completely stock L98 with 114k miles but still running strong.
Old May 6, 2004 | 05:51 AM
SweetS10v8's Avatar
Engine: L98 & 355ci
"It should have been me"
"I never win anything"
I guess its sour grapes for me today, lol j/k
But I would really like to see some numbers when avaliable.
Old May 6, 2004 | 08:32 AM
OneBadZ4U's Avatar
Glad to see more interested TPI'ers. I hope everyone has read the whole thread. They already have a test car lined up. I just found this thread. I decided to add to it instead of starting another. Hopefully one of the LT1 Intake guys will see it and post. Here's hoping we hear from John(LT1Intakes.com).
Old May 6, 2004 | 04:49 PM
pmpn's Avatar
Car: 1989 GTA
Engine: 5.7 TPI
Transmission: A4
I'm planning on going through John with the LT1 intake, some concrete numbers would be icing on the cake. Good Luck guys!
Old May 8, 2004 | 10:09 AM
Car: 89 Formula 350
Do it. I love my LT1 intake. John is a great guy to work with. I can feel a difference in throttle response, and acceleration.
Old May 12, 2004 | 10:27 AM
i8myz28's Avatar
Car: 86 z28
Engine: 355 TPI W/305 HEADS
Axle/Gears: 3/73's
LT1 INTAKE CONVERSION
HOW MUCH DOES A WHOLE SET UP COST READY TO BOLT ON...AND CAN YOU USE A TPI THROTTLE BODY??
Old May 13, 2004 | 12:12 PM
Engine: 4.0L
Re: LT1 INTAKE CONVERSION
www.lt1intake.com/pricelist.htm
Yes you reuse the stock throttle body. More answers to common questions here www.lt1intake.com/faq.htm
Old May 13, 2004 | 12:41 PM
OneBadZ4U's Avatar
Hi John. Did you ever get those Dyno Numbers from a stock TPI before & After LT1 Intake??
Old May 13, 2004 | 01:00 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
if you're still looking for someone to test with, i have a good friend with a solid, well maintained, bone stock 92 TPI350.
we're about to mod it... but if you want to do this test, i can give you his contact info and you can see if he wants to do it.
Old Jun 12, 2004 | 09:14 PM
Engine: 4.0L
Well, Tom (TKOperformance) never followed through with the deal. He had too many problems.
I still need a stock 350 that can do before and after dynos for me (TPI and LT1 intake). I will of course provide the LT1 intake. I am not going to be willing to wait all summer for the swap and dynos to happen. I prefer someone local but will consider other states too.
I prefer applicants to e-mail me to be considered. john@lt1intake.com
Old Jun 17, 2004 | 09:46 AM
John and I sorted this out. My schedule has just become too busy since I initially volunteered to help him undertake this test. It's just been too hard to get down to the track and dyno with my current responsibilities.
I appologize to the TGO members who I know are eager to see the results of this test. I've got to pass on the project to someone who will be able to get it done in a more timely fashion.
Regrets that I couldn't make it happen. I look forward to seeing the results.
-Tom
Old Jun 19, 2004 | 11:50 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Well hell, since I reconverted my IROC back to near factory for emissions, I too emailed John...if the conversion is a weekend thing, then hopefully we can have results (assuming John agrees) within the next couple of weeks.
I was reeeeeeaaallyy hoping TKO would get the info up, as I have several mild project engines that I'm intake-shopping for,the LT1 was on the list due to drivability and cost, HSR was the other, but I've seen dismal results on mild engine combos with the HSR.
camaro71633
Sep 1, 2015 10:24 AM
gta power
Aug 13, 2015 06:15 AM
ZZ42Fast
Aug 10, 2015 08:20 PM
bryan623
Aug 10, 2015 11:33 AM
L98GTA87
Aug 5, 2015 11:02 PM
