porting plenum?
Old Jan 22, 2004 | 04:38 PM
wyclefsirocz's Avatar
Car: 1989 Iroc z hardtop
Engine: peanut LB9
Transmission: slopomatic TH700R4
porting pleanum?
i know i can't spell but, i wanna port my pleanum this weekend.
but what tools woul di need. to port it. not take it out.
i was thinking a die grinder but my father is saying its not gonna work
Old Jan 22, 2004 | 08:02 PM
SMURFN' Z28's Avatar
Car: 1994 Jeep Wrangler
a die grinder, the proper grinding bits(carbide) and a vise to hold the plenum while you are grinding.
Old Jan 23, 2004 | 11:40 AM
Engine: peanut LB9
kewl thats what i was thinking
Old Jan 23, 2004 | 11:43 AM
fireturd350's Avatar
Car: '90 Formula 350
Engine: 383 SBC
Transmission: ProBuilt S/S 700-R4 & ACT 9" Stall
Axle/Gears: 10 bolt 3.23
Some gear lube comes in handy too. So you can lube up the die grinder and the bit. It will cut the metal a lot faster that way. Main thing is to warm gloves, long sleeves, and saftey glasses. The metal shards go all over the place and you will be digging at your skin for hours if they imbed in it.
Old Jan 23, 2004 | 12:50 PM
Dustin Imports's Avatar
Car: 1988 Medium Orange Metallic IROC
Transmission: 700R4 transgo shift kit
Axle/Gears: 4.10 in box lol
is there a how to w/ pics on here somewhere?
Drew
Old Jan 23, 2004 | 03:20 PM
Engine: 383 SBC
Theres a good tech article on it. Might have to do some searching to find it.
Here's a decent site with pics http://www.ws6transam.org/efi.html
Old Jan 23, 2004 | 03:43 PM
3.1EyeCandy's Avatar
Car: 1987 GTA
Transmission: 4L60e
Vader has an excellent article that I used a while back. Either search the General Tech board for it (or the TPI board)...or it might be in the Tech Articles section. --you'll want to make sure you get all new gaskets for when you're reinstalling the plenum.
Old Jan 30, 2004 | 12:23 PM
pecha's Avatar
Car: 98 T/A
Engine: ls1
here's a link to Vader's article: http://216.121.161.76/files/PlenumPorting.pdf
and here's my plenum from today (not finished yet)
Old Jan 31, 2004 | 11:26 PM
cronsformula350's Avatar
Car: 89 Formula L98 power
Engine: '96 subaru, opposed 4banger
Transmission: TH700R4, subaru 4WD
Axle/Gears: 3.27, just works
heres my 87 IROC-z Ported plenum, I used my dremel tool for this, but shortly after I bought a CH Mini diegrinder for working on my tpi base for my IROC, and wow does the amount of material removed in the same amount of time differ, I could have done 4 plenums within the same 4 hour period of time I spent porting with the dremel, high rpm cannot be replaced by a more powerful air tool.
Old Jan 31, 2004 | 11:29 PM
I took these pictures slightly off center, so it looks like I ported it weirdly. In 88 the egr port in the center was removed from the casting, so thats why my 87 has a huge metal, as where the 88's and later had a bump behind the center, but no port, so you can remove alot more material as I did with my 89's but I have no pictures of that.
Old Feb 1, 2004 | 12:46 AM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
Old Feb 4, 2004 | 08:06 PM
dj haf's Avatar
Car: 1990 IROC-Z
Engine: 350 L98
holy **** 305sbc.... lmfao u raped that plenum
did you notice any difference after you ported it?
dj haf's Avatar
Car: 1990 IROC-Z
Engine: 350 L98
bah accidently reposted... lol
Old Feb 5, 2004 | 01:31 AM
porkyzilla's Avatar
Car: 89 iroc-z 5.7tpi 350,
Engine: 5.7tpi 350,
what exactly are you grinding away??? i need a very detailed write up as i want to do this my self but have little mechanical knowledge
Old Feb 5, 2004 | 10:52 AM
Engine: 383 SBC
Check out Vadar's article it's very well wrote. He states in it that there are humps in the front of the plenum where the EGR passages are.
Old Feb 5, 2004 | 06:21 PM
92BLKL98's Avatar
Car: 1992 Black Z28 Hardtop
Axle/Gears: 2002 10 bolt w/3:23
TTT
Old Feb 5, 2004 | 07:20 PM
Ray87Z's Avatar
Car: 94 Z28
Engine: LT1 w/ headers, catback, CAI, tune
Axle/Gears: 3.23s
If you don't have a die grinder or a dremel you can do it with a power drill and a rotary file bit. I ported a couple like that, takes forever compared to the proper tool though, but it works well enough...
Old Feb 5, 2004 | 08:11 PM
JERRYWHO's Avatar
305sbc
Is that a hole in the upper right about 1/2 in from the throttle body gasket surface.
Jerry
Old Feb 7, 2004 | 11:09 PM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
Originally posted by JERRYWHO
305sbc
Jerry
Yep that's a hole but it is patched now. This TPI is Kim's (TPIgirl) and it's still being worked on (not running yet). It's a very extensively ported stock TPI.
Reid Fleming
Oct 10, 2015 09:56 PM
toronto formula
19
Oct 6, 2015 12:27 PM
bplessy
Sep 30, 2015 12:14 PM
