Taking apart TPI... Help
Old Jan 23, 2004 | 06:34 PM
iroc_cragg's Avatar
Ok I got the plenum off and all the runner bolts are out, but the runner wont come out. Do I have to take the fuel rails off or the valve covers off, anything like that.... Any help would be appriciated. Thanks
Old Jan 23, 2004 | 06:44 PM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
There are two bolts which came in from the back side, one for esch runner. Did you get those bolts???
If I remember correctly, there are 6 bolts for each side runner for the intake/runner joint. So do you have 12 bolts from this joint?
BTW: You do not need to remove the fuel rails.
Old Jan 23, 2004 | 06:45 PM
iroc_cragg's Avatar
yeah there lose. I can jiggle them around but I cant get them out.
Old Jan 23, 2004 | 06:49 PM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
If you have all bolts out, then again if I remember correctly, the runners need to rotate out. Try some finesse, do not force anything!!!!
Old Jan 23, 2004 | 08:26 PM
razor's Avatar
Car: 1992 GTA
Axle/Gears: 4.10
If the plenum is off and alll the bolts from the lower portion of the runners are out then all thats left holding them is gasket material. Just rock the runners back and forth enough and everything will sepreate. You may have to pull out the lower inside runner bolts to remove them, but by moving the runners back and forth gently the bolts should come out. After that the runners just come right off, nothing else to remove.
Old Jan 24, 2004 | 12:20 AM
CaptPicardsZ28's Avatar
Car: NCC-1701-D (docked in AZ)
Engine: impulse drive
Transmission: fusion reactors
Axle/Gears: Rescued from the Borg by my crew
The fuel rails have to be loosened and lifted up somewhat until you can work the runners out.
Old Jan 24, 2004 | 09:41 AM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
I have had mine off several times and have never had to loosen the fuel rails. I simply remove the bolts from the runners, tap it with a rubber mallet to break the gasket seal, lift them up slightly and rotate them a little to clear the valve covers and lift them out.
The Trickster!!!!!!!!!!!!!
Old Jan 24, 2004 | 10:19 AM
razor's Avatar
Car: 1992 GTA
Axle/Gears: 4.10
I have removed my factory ones atleast 20 times without having to loosen the fuel rails. I also know that the SLP runners come off without removing the fuel rail. You just need to posistion the runner at the right angle and it comes out nicely.
Old Jan 24, 2004 | 10:34 AM
Oh well!! I had to lift mine to get out the SLP runners. If I didnt I wouldnt have told him to. Life is just so wonderful for some of you, for others like me it just sux sometimes I guess. Wish I could be on top of the food chain. It would be a nice change of pace.
Old Jan 24, 2004 | 11:14 AM
speed88's Avatar
Car: 1988 Trans Am GTA
Engine: 383
I've had my runners off more times than I can recall and I have never had to loosen the fuel rails. Take out the runner bolts, wiggle it, and out it comes. Life is good up here on top!
Old Jan 24, 2004 | 12:22 PM
iroc_cragg's Avatar
ok ill try again. Thanks for all the input.
Old Jan 24, 2004 | 02:39 PM
On top and a smart azz! I cant win!!!Ahhhhhhhhhhhhh!j/k
Old Jan 24, 2004 | 05:43 PM
87-5.7iroc-z's Avatar
Car: '87 IROC-Z
Engine: L98 TPI/Possible LS1 swap
Runner bolts
How did you get to the bottom bolts behing the injectors? Not calling you out just looking for help. Trying to clean all the carbon out.
Old Jan 24, 2004 | 05:46 PM
llvll4l2c91350's Avatar
need to get to 'em from the other side with an extension.
Old Jan 24, 2004 | 05:48 PM
Car: '87 IROC-Z
I mean the ones on the outside. Not the ones on the inside. The injector and the runner blocks the veiw of them.
Old Jan 24, 2004 | 06:26 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Originally posted by 87-5.7iroc-z
i mine the ones on the outside. Not the ones on the inside. The injector and the runner blocks the veiw of them.
Old Jan 24, 2004 | 06:29 PM
Car: '87 IROC-Z
Thanks to my sect. for proof reading my post.
Old Jan 24, 2004 | 06:41 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Wait till you get the bill J/K
I use a 1/4" drive 10MM socket, a long #40 torx bit, the appropriate 1/4" drive extension and a ratchet. The 1/4" system gives me a little more room to work in.
Old Jan 24, 2004 | 06:48 PM
Car: '87 IROC-Z
Thank guy.
Hotrodboba400
Dec 10, 2019 07:07 PM
customblackbird
Oct 1, 2015 04:30 PM
Metalizer
Sep 13, 2015 12:56 PM
Fox118
Sep 12, 2015 09:29 PM
formula1LE
Sep 12, 2015 08:31 PM
