car wont start after porting intake
Old Jan 24, 2004 | 11:13 AM
carbgeek's Avatar
i pulled my intake off to port it and now the car starts for second then shuts back off any suggestions
Old Jan 24, 2004 | 11:43 AM
3.8TransAM's Avatar
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
Make sure everything is hooked back up correctly(vacuum lines electrical connections etc)
Are u sure everything is installed into the correct orientation?(ie u dudnt swap runners side to side?) I've seen it done...
Did u make sure the intake end seals are actually sealed? did u use silicone or the little rubber inserts that come with ther intake gasket?
Install the distributor to tdc #1 cyl and correct firing order and the timing set correctly?
all i can think off the top of my head right now
Later
Jeremy
Old Jan 24, 2004 | 11:52 AM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Make sure all bolts are properly torqued to prevent any vacuum leaks.
The Trickster!!!!!!!!!!!
Old Jan 24, 2004 | 12:32 PM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
The porting could not be the reason for your problem. You did not put it back together properly. I dont know what it is, but you will find it eventually.
Do what the above posts suggest. You have alot to check.
Old Jan 24, 2004 | 12:45 PM
speed88's Avatar
Car: 1988 Trans Am GTA
Engine: 383
Later
Jeremy
Do all of the checks that he recommended but also check you IAC. That's the peice underneath your throttle body. Was you throttle body knocked around or dropped when it was off the car? The sensor in the IAC may be gone. To check it, simply unscrew the sensor form the IAC housing and shake it gently, if you here any "peices" moving around then your IAC sensor is gone. Get a new one, plug it in, and away you go.
P.S. This is the experience I had when I ported my stock intake. Somehow the IAC got damaged and the car would'nt start.
Old Jan 24, 2004 | 01:32 PM
carbgeek's Avatar
ok now it will run for 30 seconds then shut off its weird like its fuel or something but its holding pressure dunno
Old Jan 24, 2004 | 01:35 PM
speed88's Avatar
Engine: 383
Ok well if ya want to get technical, then yes mine did start. It would stay going for a few seconds, surge up in the rpm, and then shut off. In order to keep it going I would have to hold the throttle as soon as it started. Check your IAC.
Old Jan 24, 2004 | 03:57 PM
dj haf's Avatar
Car: 1990 IROC-Z
Engine: 350 L98
check your IAC and your TPS voltage since you were messing around with the intake and tb. is your car MAF or SD?
Old Jan 26, 2004 | 01:07 PM
bnoon's Avatar
Car: 2008.5 Mazdaspeed 3 GT
Engine: 2.3 DISI Turbo
Transmission: 6 speed MT
When I did my SLP runners and ported the intake to match, I had to start the car ten times or so before it would stay running when it was all back together. It just took that long to work all of the air out of the fuel lines... even after *priming* the system by turning the key on, off, on, off several times to pump up the lines with the fuel pump.
Can you keep it running with the throttle or not?
Wade787b
Sep 29, 2015 01:15 PM
mx127
Aug 10, 2015 08:13 AM
mustangman65_79
Aug 8, 2015 12:07 PM
92projectcamaro
Aug 6, 2015 01:20 PM
