Victims of mileage
Old Jan 24, 2004 | 04:16 PM
camarocruzin's Avatar
Car: '89 Iroc
Transmission: 700-r4
Victims of mileage
I am curious as to what parts are the first to begin detioriorating due to increased milieage. My car is an 89 Iroc with an L98 and 700r4 trans with 2.77 gears. I got a job offer that would cause me to comute and extra 10-15(I now drive 3 miles each way) miles each way each day. I am trying to weigh the increase in pay against the wear on the car. All but maybe 2 miles each way would be down the highway during non-rush hour (2-10shift). The car has 91,000 miles on it now and is running great, was very well maintained by the previous owner, and i would like to think that i am just as diligent. Thanks for anything.
Josh
Old Jan 24, 2004 | 04:20 PM
D Stroy H8's Avatar
Car: 1990 Iroc-Z
It should be fine. Of course with high mileage problems rear up everywhere and everytime you turn around - that's the nature of high mileage.
The fact that you maintain it diligently is a card to your advantage.
YOu have already minimized potential problems, but there is nothing you can do it to rewind the clock
...short of a full restoration.
Old Jan 24, 2004 | 04:22 PM
Car: '89 Iroc
anything that would wear faster with the higher average speeds of the highways, like wheel bearing wearing faster than i need to do the brakes, or things like that? thanks
Old Jan 24, 2004 | 04:33 PM
Morley's Avatar
Unless it is a lot of stop and go traffic, then tires would be about the only noticable wear increase. It is actually better for your engine to run longer, gives it a chance to get up to operating temp and evaporate any moisture in it.
Old Jan 24, 2004 | 09:40 PM
Car: '89 Iroc
thanks i guess i'll just keep drivin in and wait until something happens, i'm always lookin for a good excuse to rip it apart
Old Jan 26, 2004 | 11:28 AM
ploegi's Avatar
Car: 1988 Pontiac Firebird Formula
Engine: 5.7 TPI
I used to drive my formula 35 miles one way to work. Mostly backroads, but, not a lot of stop-and-go. I have 178000 miles on it now, and it still runs good. (although, I did have to replace the rear end, carrier bearings where getting noisey, rebuilding the b/w rear was a pain, trying to find parts for it was a real drag.)
Old Jan 26, 2004 | 11:33 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
if you maintain it and dont abuse it, the only easily forseeable problems is the valve seals start to leak at startup (usually around 100-120k) and around 120-135k, expect to overhaul the 700r4
Old Jan 27, 2004 | 10:35 PM
Car: '89 Iroc
sounds like nothing to look forward too, but thanks for the replies guys
PurelyPMD
May 5, 2016 04:57 PM
plm99
Southern California Area
Nov 16, 2015 05:21 PM
sammy52401
Nov 11, 2015 07:20 PM
bjpotter
Oct 15, 2015 11:07 AM
Saxondale
Carburetors
33
Oct 1, 2015 10:26 AM
