Help with build-up
Old Jan 26, 2004 | 08:45 AM
Jekyll & Hyde's Avatar
Car: 1988 Camaro IROC-Z
Engine: 350 TPI (L98)
Axle/Gears: 9-bolt 3.45
Help with build-up
Need help choosing head to match setup. I am going to call comp cams for the cam.
Engine: 88 L98 with cast iron heads
Intake: TPIS Big Mouth, SLP siamessed runners, ported plenum
Exhaust: Edelbrock headers
1) L98 aluminum heads -
I can get these for $400, they are completely stock, but I would have them ported.
2) Dart Iron Eagle -
These seem to be the best smaller cc, it will match the intake system will well. $900 from Summit.
I am trying to stay under $1,000 for the heads. Any other heads that I should consider, let me know.
Old Jan 26, 2004 | 10:09 AM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
Canfield 195's.
Old Jan 27, 2004 | 08:09 AM
I think that the 195s will be a little too large for the LTR system, won't they?
Old Jan 27, 2004 | 02:16 PM
TKOPerformance's Avatar
Car: '86 Camaro, '02 WRX, '87 K5, '67
Engine: 350 TPI, 2.0turbo, 383 in the works, 289-4BBL, 232, A-head 4-cylinder
Transmission: T56, 5-speed, 700R4, C4, T176, semi-auto 2-speed
Axle/Gears: 3.73, 3.90, 4.88, 3.55, 3.54, 7.00
I'd go with the L98s and port them yourself. A porting kit is like $45 and a cheap air die grinder is like $25. The rest if your time, which doesn't cost a thing.
Old Jan 27, 2004 | 10:23 PM
D Stroy H8's Avatar
Car: 1990 Iroc-Z
Port the aluminum L98s, take your time and be patient and they will flow great! Better than out of the box DARTs for half the money and you'll learn (shiiiiiiiat)
Old Jan 30, 2004 | 08:45 AM
Cool thanks guys. I was just reading in a Chevy Hi Performance book and they were really speaking poorly of the Aluminum L98 heads, and said "only get them if they are cheap".
They seemed to love to head types, Vortec and AFR 180 & 190. I get tired of reading that part of the book because they can't repeat enough.
Old Jan 30, 2004 | 01:34 PM
The Vortec heads are amazing, and I would definately run them over the L98 aluminum heads if cost wasn't a factor. The problem is that you need a $400 lower intake to run the TPI on the Vortecs.
Especially at low lifts a stock set of Vortecs will outflow GM Bow Tie heads. With a little port work there's little to touch the Vortec as a street head except fof the AFRs.
WhiteLightnin83
Jul 12, 2006 02:20 PM
Maverick_IX
Feb 15, 2006 06:06 PM
TA4me
Jul 5, 2005 02:55 PM
raefon
Dec 31, 2003 12:01 PM
Mrfixit
Jul 18, 2001 12:35 PM
