Cam question, and HP estimate?
Old Jan 28, 2004 | 06:17 PM
FruityOne's Avatar
Car: 1989 TransAm GTA
Engine: One sweet modified 355 TPI.
Transmission: The kind that shifts....
I knew that one day I would ask this question, i just didn't think I'd be asking this so soon!
In any case heres what I got. Literally. I was browsing Ebay and saw a Lingenfelter cam for sale. New in box all that nice stuff. Picked it up for $250 minus shipping.
Nitty gritty, any care to estimate how much power this cam will make with a ported plenum, AS&M siamsed runners, port matched intake base, and pocket ported heads? I will get headers, don't have them right now though. Car will also have a custom prom thanks to a friend.
Cam specs..
LPE 74211 camshaft
Lift w/1.5 rockers, .499/.525
Duration 211/219 @ .050
Centerline 112*
Powerband is idle to 5,400rpm, so it should work well with the TPI.
I've read up alot on the LPE cams here, but most of them talk about the 219/219 cam, and briefly mention the cam I bought. Anyone care to give some info on possible #'s or times? Even if what the maximum potential might be?
Old Jan 28, 2004 | 08:48 PM
Guest
Guest
Posts: n/a
just go and pull out desktop Dyno2000 its a nice program... hehehe
Old Jan 28, 2004 | 08:59 PM
biggtime's Avatar
I had that cam with 1.6:1 rockers, edelbrock base, slp runners, 52 mm throttlebody, edelbrock performer centerbolt heads. 10:1 compression. NA 325RWHP 5500Rpm. Great cam
Old Jan 28, 2004 | 09:45 PM
FruityOne's Avatar
Yeah, just got DD2000. Started playing with it, and I had to guess at some settings so I wasn't sure how accurate it was.
But its showing something similar to your results right now.
300hp @ 5,000rpm, and 387lb/ft @ 3,500rpm. The torque is pretty much flat from 2,000rpm to 4,000rpm.
Still seems high to me. If anyone has made a L98 Cam profile then point me to it. I had to guess on the intake centerline but I got the rest.
And I used the L98 head profile with a 10% boost in flow as an estimation for the pocket porting.
Old Jan 29, 2004 | 10:19 AM
mike graycar's Avatar
Car: 88 iroc x 2- 1 T-Top, 1 Vert
Engine: 350 tpi, 305 tpi
Transmission: 700R4-2800 stall, 700R4 stock
great cam. i have the 219. you will not be dissapointed. 211 is great for tpi. 219 is for tpi w/ superram or something similar.
Old Jan 29, 2004 | 09:40 PM
FruityOne's Avatar
I've been doing a lot of reading up on this particular cam. I've found a LOT of people in the low 13's and high 12's with it. Now, they are using much better heads than I, and a little higher compression.
Heck, when I bought it all I was thinking of was high 13's. If the cam can support that, heck yeah. Time to start saving for some good heads.
I did some dyno 2,000 simulations, but I must have something wrong with the sims. The #'s seem much higher than I think they should be.
beastin91rs
Oct 9, 2015 07:38 AM
bellez77
Sep 5, 2015 08:39 PM
theurge
Aug 21, 2015 12:46 PM
redmaroz
Aug 16, 2015 11:40 PM
Fronzizzle
Aug 9, 2015 01:15 PM
