Got my heads....got some Q's.....
Old Feb 5, 2004 | 09:53 PM
PhantomTPI's Avatar
Car: 1986 Pontiac Trans Am
Engine: 5.0 TPI
......ok so I picked up a donor set of 416 heads last night....14014416 is the full casting #. Here is what i plan on doing to the 305:
*Send out heads, have them pressure tested/magnafluxed/acid dipped to clean them/decked(if necessary)
*New springs/valves
*Port/polish, gasket match, etc
On top of that, I will be adding the following to the motor:
*Summit Cam/Lifter part #SUM-K1102 (262/int, 272/ex)
*Hooker 2055's
*SLP Runners
*58mm Throttle Body
*POSSIBLY all new MSD parts instead of keeping the Accel Stuff
*Entertaining the idea of SVO injectors
So i have the following questions:
*Is it reccomended that I touch the intake ports at all on the intake itself and/or the heads?
*Good idea to have the shop mill the heads a bit to give more compression?
*Since I'll have a full exhaust after the headers, I'm just wondering what kind of power I should be making roughly HP wise....
Thanks everyone...
Old Feb 6, 2004 | 09:43 AM
PhantomTPI's Avatar
Engine: 5.0 TPI
TTT
Old Feb 6, 2004 | 11:33 AM
1bad91Z's Avatar
Car: Faster
Engine: Than
Transmission: You!
If you're going that route, then do ALL the above except, get a 52mm TB instead of a 58mm. Port-match the intake to the heads, and portmatch the plenum to runners and 52mm TB. Gut air box too. I'll have ram-air boxes available for purchase soon. They will be just like mine, only the new ones will be made out of ABS plastic.
Here's a pic of my metal boxes:
Old Feb 6, 2004 | 11:34 AM
1bad91Z's Avatar
Car: Faster
Engine: Than
Transmission: You!
2.
Old Feb 6, 2004 | 11:36 AM
1bad91Z's Avatar
Car: Faster
Engine: Than
Transmission: You!
Oops, sorry, I just realized you have a firebird. The boxes will only fit Camaro's.
Old Feb 6, 2004 | 11:41 AM
PhantomTPI's Avatar
Engine: 5.0 TPI
Hehe, thats ok.
Ok, i'll get the 52mm TB instead. I just wasnt sure if port-matching the intake to the heads, and the plenum to the runners was a good idea or not since this is a 305, not a 350 or something else that makes more power.
What kind of power should I expect from doing all this?
Old Feb 6, 2004 | 12:41 PM
1bad91Z's Avatar
Car: Faster
Engine: Than
Transmission: You!
I would estimate about 250 - 260 at the rear wheels (provided you have the PROM tuned correctly for the changes), AND a butt-load of torque!
You will notice a decent increase.
Old Feb 6, 2004 | 01:17 PM
PhantomTPI's Avatar
Engine: 5.0 TPI
Not bad #'s for a 305. I'd probably have to have a custom prom done to get those #'s though.....definetly necessary for the SVO injectors....
Old Feb 6, 2004 | 02:27 PM
1bad91Z's Avatar
Car: Faster
Engine: Than
Transmission: You!
I can do your custom PROM. PM me if you need help with it.
calgutie
Nov 5, 2012 10:39 AM
Jaysz28
Jan 13, 2012 02:49 PM
GTA Sammy
Mar 3, 2009 01:48 PM
irocdaddy
Northern California
26
Dec 14, 2008 06:10 PM
