tpi to carb conversion . What distributor gear do I need ?
I'm putting a tpi motor in a monte and I am converting it to a carb setup with an hei distributor . I know the tpi has a roller cam . Do I need a special gear for it ? Sorry if it's a dumb question . I usually work on fords , and when you convert to a carb with a roller cam you need a bronze dizzy gear . Is it the same on a chevy ? Thanks for the help people :hail:
86IROC112
08-17-2015 02:00 PM
Sanjay
08-12-2015 03:41 PM
