Da#% IROC wont start, any ideas...please!?
Car: 1986 IROC-Z28
Transmission: Boring Automatic
I'll cut to the chase. I replaced the Fuel injectors on my 86 IROC. I had everything hooked back up and started it up. I noticed I had a pretty bad antifreeze leak coming from the inlet to the heater through the firewall. So, I shut it off after having it running for about 1 minute so I can repair this leak. After about 30-60 minutes of repair time, I go to crank it back up. NOTHING. Nothing works. I can turn it to accessories and things light up inside, but when I turn it to "start", everything goes quiet and dark. When I did get it started before that, it sounded awesome. I just wanted to know if anyone had any suggestions as to where to look. Maybe a ground or something? I know it is not the battery because I swapped one from a newer Z28 in (same typed used) and same thing happened. ANY thoughts are greatly appreciated. Thanks in advance from a long time looker, short time typer (to this board) I have gotten much help from other postings here, i figured someone might be able to help me out!
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Did you by any chance disconnect any wire harnesses in that area while you were fixing that leak. Like maybe the harness on the ignition coil.
Car: '87 IROC
Transmission: 700-R4
sounds like a connection problem. check the connections at the battery and ground to the car. make sure theres no corrosion or rust or anything. would be a good idea to take them off and clean them w/ a wire brush.
let us know
let us know
mustangman65_79
Aug 11, 2015 03:17 PM
