whut mods should i do???
Old Feb 12, 2004 | 08:35 PM
Jackman5003's Avatar
Car: 1984 S-15
Engine: 1988 Iroc-z 305 V8
Transmission: T-5 (5-speed)
i got a BONE STOCK...can't get anymore stock '88 305 outta my brothers IROC in my s-15. i can't do headers becaseu tehres no room. so whut should i do as far as mods? and leave out superchargers, turbos, and NOS...
Old Feb 12, 2004 | 08:53 PM
posbird87's Avatar
Car: 87 formie
Engine: none
Transmission: none
um... yes, you can do headers. theres companies that make then for SBC swaps in S-10 and S-15's. My friend has a 307 in his 88 S-10 and it has headers.
what you can do depends on the tools you have. you can port out the plenum, runners, and intake, or buy some SLP runners and siamese them, make your own CAI, LT1 cams go for pretty cheap, can add some roller rockers too.
Old Feb 12, 2004 | 09:16 PM
Car: 1984 S-15
i can't use headers because i'm useing the t-5 tranny and the other, longtube headers, i have camaro wheels in the front and they'll rub with the pipe that goes outside the frame. it would work just if i could do something with those 2 pipes that run out into the wheel wells.
Old Feb 12, 2004 | 09:32 PM
D Stroy H8's Avatar
Car: 1990 Iroc-Z
Try block hugger styler headers. Those are designed to fit into the cramped spaces that develop inside street rods. Worth a shot.
Anyway... cold air intake, hugger headers, catback, u/d pulleys, ported plenum, ported base. That handful of mods will do for stage-1 VERY nicely
After that, some cost effective world products heads and a carefully chosen cam will do wonders for all the new breathing capacity.
Old Feb 12, 2004 | 10:04 PM
5SIZ's Avatar
Car: 1987 IROC-Z
I was thinking of recommending the same thing, but you can definatly fit regualy shorty headers in there..
if you put huggers the flanges face the ground, and a custom y-pipe will have to be made for them..so why not put in shortys and have an exaust shop make a custom y-pipe for them so you wont have any rubbing problems?
it's not hard, just think it out.
Also i it lowered? people usually lower those kind of trucks. if not then run dual exaust lol.
Old Feb 12, 2004 | 11:19 PM
posbird87's Avatar
Car: 87 formie
Engine: none
Transmission: none
hmm, thats odd, i cant remember off the top of my head but he does have long tubes, im pretty sure, and he has camaro rims all around. but he does have a 350 trans... that must be makin the diff
Old Feb 13, 2004 | 08:49 AM
Car: 1984 S-15
yea they wrk and all but if u turn the weel they rub the tube. and if u forget to uncut ur wheels when u park then u can burn i hole in ur tire(or so i've heard)
look at the space i have here guys...
http://www.cardomain.com/memberpage/516311
Old Feb 13, 2004 | 08:52 AM
Car: 1984 S-15
i also looked at those hugger hueaders. they won't work because they'd empty out RIGHT on the crossmember. if u guys can find any that collect maybe 2/3 of the way back from the front(like the stock manifods) they would work. i can't tho
starliner
Feb 9, 2016 08:18 PM
Quzyle
Oct 15, 2015 03:35 PM
Cole Curtis
Theoretical and Street Racing
Oct 3, 2015 12:26 AM
