Tach inaccurate
Old Feb 16, 2004 | 07:42 AM
ANDYZ28's Avatar
Car: 1982 Z-28
Engine: 5.0 w/ Holly carb
Transmission: TH-700R4
Tach inaccurate
I am not sure if this is the correct forum, but; I have a 1990 5.7 TPI IROC-Z with a very inaccurate tachometer. @2000 rpm it indicates 3000 rpm. Has anyone experienced this problem? I have the original factory service manual and it has no reference to this condition.
Old Feb 16, 2004 | 07:44 AM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
it is a very common problem with the tachs in our cars, mine is so bad, that i shift well past 7k on the tach.
Old Feb 16, 2004 | 07:58 AM
ANDYZ28's Avatar
Car: 1982 Z-28
Is the tach itself at fault? Shoud I replace it with a new one, if they are still available?
Old Feb 16, 2004 | 11:36 AM
87camz28's Avatar
Car: 1987 Camaro Z28
Engine: 5.7L, L98 slightly modified
Non Functional Tach
ANDYZ28,
My tach stopped working in my 87 Z28. I installed an MSD 6T ignition box and a Autometer Shift Lite tach and it started working again, I left the Shift Lite tach in place. You may have a loose wire causing your problem. If you want to try to replace the tach, try ebay. I haven't seen individual tachs up for auction, but have seen whole instrument clusters go for as little as $45.
Old Feb 16, 2004 | 11:49 AM
ANDYZ28's Avatar
Car: 1982 Z-28
I have several of the 82-89 instrument clusters, but the 90-92 clusters are quite different. It is rare to see one on eBay for a V8.
Old Feb 16, 2004 | 12:45 PM
87camz28's Avatar
92 Instr. Panel
Sorry, didn't see that you had the 90-92. There's a local guy here that deals in nothing but used Camaro / Firebird parts. He's pretty reasonable on prices, I bought a set of 90-92 RS/Z28 wheels from him for only $225. He is just outside of Columbia, SC.
Jerry @ Brock's Camaro & Firebird (803) 955-3181.
I also found this one on ebay.
http://cgi.ebay.com/ebaymotors/ws/eB...tem=2461271647
$750 L98
Feb 1, 2025 02:25 PM
Eric-86sc
Sep 28, 2015 11:37 AM
RedLeader289
Sep 23, 2015 06:50 AM
TrevinE
Sep 14, 2015 03:20 PM
86IROC112
Sep 11, 2015 04:04 PM
