removing vaccum lines safely
Old Feb 16, 2004 | 03:38 PM
demon138's Avatar
Car: 89 Pontiac GTA Trans Am
Engine: T.P.I. 383 Stroker
Transmission: Monster 700R4
what lines can i remove on my tpi and what will the effects be?
Old Feb 17, 2004 | 01:53 PM
demon138's Avatar
Old Feb 18, 2004 | 08:54 PM
91banditt2's Avatar
Car: 1991 BandittII Firebird
Engine: 5.7 HSR
Axle/Gears: 3.27 9 bolt
ok i'll bite
why do you want to remove vac. lines?to replace them?to uncludder the ehgine compartment?
alilttle more info please.
Old Feb 18, 2004 | 10:08 PM
thirdgen88's Avatar
Car: 1995 Corvette
Transmission: 6 spd Manual
Axle/Gears: Dana 44, 3:45:1
If you remove them all, you'll have a big vacuum leak, your engine won't run right and you won't be able to stop...
Old Feb 18, 2004 | 10:34 PM
91banditt2's Avatar
Engine: 5.7 HSR
and that would be bad mmmmk.
Old Feb 18, 2004 | 10:37 PM
thirdgen88's Avatar
Car: 1995 Corvette
... but you can do it, its all up to you mmmmkayyyy??
I love South Park the movie..
Old Feb 18, 2004 | 11:22 PM
C20T/A's Avatar
Car: C-20
Engine: 260 boat anchor Mexican 350 (crate) TPI (MAF)
Transmission: THM-400 I turn 3500 (which is where my pos engine's power starts droping off) at 80 I need a 4L80-E
I did that once just for fun on my MAF TPI while i was finnishing up the instalation if the injection. ;D
A 350 running at 250 RPM's and lean sounds interesting (Like it has a racing cam) but it is not an intelegent thing to do and will cause you all sorts of trouble if you can mannage to keep it running with that much of a vacuum leak.
So don't do it mmmmmkayyy. (I had to join in on the fun)
Old Feb 18, 2004 | 11:25 PM
C20T/A's Avatar
Car: C-20
on second thought If you want/need to remove them, then use pluggs on your open vacuum ports (do not remove the one going to your brake's power assist unless you like using both feet on every stop)
Old Feb 19, 2004 | 12:28 AM
thirdgen88's Avatar
Car: 1995 Corvette
Thats interesting... I've never seen an inverse vacuum leak that actually decreases RPM's...
Old Feb 20, 2004 | 01:33 PM
demon138's Avatar
which vac lines goto the ac and heater controls,and whatabout the heater valve ?
Old Feb 20, 2004 | 01:36 PM
thirdgen88's Avatar
Car: 1995 Corvette
There should be two vacuum lines coming out of a bundle back by where the heater hoses connect to the heater core... The longer one is for the heater control valve, and the shorter one is for the control doors...
Old Feb 20, 2004 | 01:38 PM
91banditt2's Avatar
Engine: 5.7 HSR
on my 91 Firebird there is a small hard vacume line ran in with wiring harness along under the cowl on the passenger side.
Old Feb 24, 2004 | 12:15 AM
C20T/A's Avatar
Car: C-20
Your TPI is a 91 which is MAP based My TPI is an 89 which is a MAF system that cannot determine if excess air is entering the system after the sensor so it acts opposite of your system that is vacuum based and can sense the leak. Either way it is bad to have a leak.
Old Feb 24, 2004 | 07:57 AM
thirdgen88's Avatar
Car: 1995 Corvette
I was making fun of a typo, thats all... he meant 2500 RPMS... vacuum leaks increase rpm, not decrease, no matter what system you have... just a little humor thats all...
Frozer!!!
Jan 19, 2024 04:55 PM
Polo Z03
Sep 10, 2015 06:43 PM
Ron U.S.M.C.
Sep 7, 2015 08:38 AM
BurlyChev
Aug 22, 2015 01:52 PM
3rdgenparts
Aug 8, 2015 07:09 PM
