just got 85 305tpi running got some ques?
Old Feb 17, 2004 | 05:16 PM
V6camaroman's Avatar
hey guys i just got my 85z28 up and runnig again. it wouldnt start before and i had no spark so i did a complete tune-up on it (accel wires, cap, rotor, supercoil and bosch platnums) anyways doing all that to it made it start and run good again. i only have two ques though. the car starts and runs great now with no hesitations but it wont idle... i planed on correctly setting the idle air control valve and throtle positon valve. will that fix my idling problems? and make it run 100%
Old Feb 17, 2004 | 06:12 PM
well i just went outside to play with her and all i did was take a torx screwdriver and raise up the idle for now it now idles about 1000 rpm. i still need to propperly adjust them though
Old Feb 18, 2004 | 12:50 PM
CaptPicardsZ28's Avatar
Car: NCC-1701-D (docked in AZ)
Engine: impulse drive
Transmission: fusion reactors
Axle/Gears: Rescued from the Borg by my crew
Doing both of the above should fix the idle issue unless you have a vacuum leak as well. TPS should be set at .54, and check setting on IAC valve. Good luck.
eightsixseven
Dec 16, 2024 01:50 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Fast355
Dec 2, 2016 06:33 PM
perZ
Aug 21, 2015 05:51 PM
jbd1969
Aug 17, 2015 07:06 PM
