code 42 help please
Old Feb 18, 2004 | 03:40 PM
92Formula305's Avatar
code 42 help please
I am fixing up my formula so that I can sell it and I need to fix a code problem. It is a '92 with the 305TPI/5spd. It will produce a code 42 just seconds after starting. while the light is on the engine is weak and stumbles. It runs, but very crappy power. It usually goes off in about 2-3 miles of driving and then it will run smooth and with normal amounts of power. The info I can find says that the code 42 is either a low voltage at the ESC module OR knock sensor. How can I single out which one it is? Does someone know which wire and what voltage the ESC module is supposed to have? How can I test knock sensor? any help would be great. Thanks alot.
Old Feb 18, 2004 | 03:52 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
code 42 info
Hello 92Formula305,
Check your e-mail, you have a package.
Old Feb 18, 2004 | 03:54 PM
awesome thanks!
Old Feb 18, 2004 | 04:00 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
You're welcome!!!!!!!!!!!!!
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Falcon50
Aug 22, 2020 03:26 PM
racereese
Oct 3, 2015 03:46 PM
Luigytico09
Oct 1, 2015 08:46 AM
dusterbd
Sep 29, 2015 08:40 AM
