What's this bolt for?
Car: 1989 GTA
Engine: 5.7L
Axle/Gears: 3.27 BW 9-bolt
I've always wondered what this bolt in the TPI manifold is for...the one in the picture below that's next to the water neck and the fuel injector. It's straight up and down and doesn't thread into the cylinder head; it's just a blind hole.
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Someone else in here might have a better idea of what it is. But the only thing I can think of is that there are three more of those holes around the engine and they are hoist points for removing the engine.
Car: 1991 BandittII Firebird
Engine: 5.7 HSR
Axle/Gears: 3.27 9 bolt
it along with the two intake bolts are also used to mount a lifting eye.ya know something to yank yo moto out
Car: `86 SS / `87 SS
Car: 1989 GTA
Engine: 5.7L
I had thought about putting an eyelet into it and using it for a lift point while I change motor mounts, but there really isn't much material around it. I'm pulling the exhaust manifolds to install headers anyway, so I'll just use an exhaust manifold bolt hole to lift the engine up.
I had always wondered what purpose the the mystery bolt hole had. I suspected it was used on Corvettes.
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
On mine it was used to hold a clip that holds the wiring harness that goes to the injectors and alt.
DO NOT use that as a lifting point. Think about it. Blind hole. ALUMINUM. Small hole. Big heavy engine. ALUMINUM.
Car: 1989 GTA
Engine: 5.7L
Numbah-1
Sep 12, 2015 08:57 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
