Harness Hassles
Old Feb 19, 2004 | 10:52 AM
Cra-Z-Canuck's Avatar
Car: 88 IROC Convertible
Engine: 355 (Finally!)
Transmission: Auto :(
Harness Hassles
When re-attaching the fuel injector harnesses, how do you know which one goes on which injector? They are in 4 groups of 2 harnesses each. Does it matter within each group (does it batch fire 2 at the same time maybe?). We fired the new motor up for the first time last night (very exciting) but it was running like a bag of crap (very demoralizing). Any thoughts on this harness problem?
Old Feb 19, 2004 | 11:11 AM
Scott_92RS's Avatar
Car: 1992 RS
Engine: 406 Stealth Ram
They all fire at the same time. Check the timing, vacuum, DTC codes, etc, they might be able to help you diagnose your problem.
Old Feb 19, 2004 | 11:27 AM
All 8 fire at the same time? Or just each group of 2?
Old Feb 19, 2004 | 11:36 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
batch..... left bank and right bank fire separately.
athough it shouldnt run cruddy, even if you completly crossed them...
Scott_92RS's Avatar
Car: 1992 RS
All 8 fire at once...
Batch = All injectors at same time
Bank to Bank = 1 side, then the other
Sequential = Each injector fires individually.
Old Feb 19, 2004 | 11:45 AM
Thanks guys! Much appreciated. I'll look for other problems.
Old Feb 19, 2004 | 11:50 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
batch really means.... they fire in a batch... any group of more then one injector can be considered a batch.
bank to bank is a TYPE of batch injection.
so yes, TPI is bank to bank batch injection.
straight from dictionary.com
batch1 ( P ) Pronunciation Key (bch)
n.
An amount produced at one baking: a batch of cookies.
A quantity required for or produced as the result of one operation: made a batch of cookie dough; mixed a batch of cement.
A group of persons or things: a batch of tourists; a whole new batch of problems.
Computer Science. A set of data or jobs to be processed in a single program run.
tr.v. batched, batch·ing, batch·es
To assemble or process as a batch.
Old Feb 19, 2004 | 11:54 AM
Scott_92RS's Avatar
Car: 1992 RS
TPI is not a bank to bank system. All 8 injectors fire at one time. Its a batch fire system that just so happens to have all 8 injectors in the batch.
Old Feb 19, 2004 | 01:38 PM
Captain C's Avatar
Car: 1985 IROC-Z
Engine: 1989 350 4 bolt roller block
Transmission: ProBuilt 700R4 Road Race with Edge 9.5" 2800 stall lockup converter
They actually fire twice for each cycle. Half the mixture on one shot and the other half in another shot. That way it keeps the fuel/air mixture flowing. Not the best way to do it but it works. Sequential Port Injection works better.....
Old Feb 19, 2004 | 08:14 PM
eric305TPI's Avatar
Car: 82 ElCamino, looking for a 3rd gen
Engine: 305 TPI(427SB in progress) 730 $8D
Transmission: THM350 (Getting a 4L80E soon)
Axle/Gears: 10 Bolt w/ 2.43 gears :(
The pink/black plugs go on the odd bank(drivers side) and the light green/ black go on the even bank(passenger side). If you did some heavy mods to the motor you might have to do some prom tuning to get it to run, or at least let it go into closed loop to adjust the fuel trim.
Old Feb 20, 2004 | 08:29 AM
I guess you'd call them heavy mods in the sense that this 350, while not that crazy (cam, slight porting) is replacing a 305 - but I switched to a 24# lti injector, so my thinking is this - fuel injectors are delivering more fuel than the computer thinks they are but the motor is bigger than the computer thinks it is - so they should balance out. I am getting a custom prom done very soon though from Westers Garage in Alberta.
Bohemian
Aftermarket Product Review
Nov 25, 2015 09:38 PM
rs_z28_vert
Sep 30, 2015 09:47 PM
z28joe2
Sep 28, 2015 05:54 PM
Eric-86sc
Sep 28, 2015 11:37 AM
efiguy
Sep 27, 2015 01:30 PM
