LPE 219 cam and dist. gear??
Old Feb 19, 2004 | 11:07 AM
91wtROH17's's Avatar
Car: 91Z
Engine: 355/afr/sr/lpe219
Transmission: built 700R
Do I need a bronze distributer gear for the LPE 219/219 cam?? I was sure I would, but want to be positive. Thanks
Old Feb 20, 2004 | 01:32 AM
Acceld Z's Avatar
Car: 1992 Z28
Engine: 355
No.
Old Feb 20, 2004 | 06:43 AM
Car: 91Z
No?? I thought when I called they said I would?? Awell you have the cam, so I'll go with NO.lol Thanks acceld, I should have just PM'd you.
Old Feb 21, 2004 | 04:04 AM
Acceld Z's Avatar
Car: 1992 Z28
Engine: 355
No, they use iron distributor gears that allow you to use the OE gear on the distributor. You may want to throw a new GM gear onto the distributor anyway. They're only about $18 Canadian.
Old Feb 23, 2004 | 06:55 AM
Car: 91Z
I will put a new one on for sure.
Old Feb 23, 2004 | 07:42 PM
redrummer's Avatar
Car: '88 Trans Am GTA
Engine: 5.7L L98
Axle/Gears: 3.27 Aussie 9 Bolt
I'm using the OE gear, no problem.
Old Feb 24, 2004 | 07:19 AM
Car: 91Z
I found out why I was confused!! I called LPE and they told me the cams they had on sale for $250 needed a bronze gear. That's where the confusion came from.
Old Feb 26, 2004 | 06:17 PM
Paul Riccioli Jr's Avatar
Car: 89 IROC-Z
Engine: 383
Now that's interesting.....I bought one of their 219 cams on sale last summer and installed it with my stock dist. gear. Do you happen to have the part numbers for both the cam that requires the bronze gear and the one that doesn't??
Old Feb 27, 2004 | 09:21 AM
Car: 91Z
If you go to the website I think they are still on sale(part #'s are there). I would just call LPE tech and see what they say. Paul I honestly think you are fine, I could have misunderstood what the guy was trying to tell me???.
junkcltr
Aug 2, 2019 11:12 PM
beastin91rs
Oct 9, 2015 07:38 AM
camaro71633
Sep 1, 2015 10:24 AM
86White_T/A305
Aug 17, 2015 12:16 AM
