Would I run 12's with this??
Old Feb 19, 2004 | 11:55 AM
speed88's Avatar
Car: 1988 Trans Am GTA
Engine: 383
I am considering building a 383, or rebuilding my 350. I am not sure what I want to do. I know I would like to have a mid 12 second car on motor. I have a NX 150 wet kit to get me into the 11's. What do you think this combo would get me?
350 w/:
BBK 52mm tb
TPIS Miniram
TPIS Prom
AFR 195's
LT4 Hotcam w/1.6 rocker
MSD 6a
MSD Pro Billet Distributor
MSD Coil
Underdrive pulleys (Not sure which brand yet)
Meizere Electric Water Pump
TCI 3000 stall converter
Edelbrock TES headers
Flowmaster 3" exhaust
The block will consist of a stock polished crank, Weisco pistons, Eagle H-beam rods, Speedpro bearings, 10:1 compression
Would that be good for mid 12's with traction. I have Nitto's and lca's, lca brackets, sfc's, etc, so the chassis is not a problem.
What would the same combination run except with 383 cubic inches, and a Eagle 4340 forged crank shaft?
Any and all help would be greatly appreciated here guys. Thank you.
Old Feb 19, 2004 | 09:11 PM
D Stroy H8's Avatar
Car: 1990 Iroc-Z
It all looks pretty good for mid 12s at least high 12s. Except for the headers. The TES headers are kind of restrictive, so I would go with Hooker Super Comps or SLP if hooker is too expensive for you. I would also do a minimum head port job (3 angle valves, some bowl blending and some port matching). THat should be good for mid 12s definitely.
Old Feb 20, 2004 | 10:35 AM
speed88's Avatar
Engine: 383
Anyone else have any opinions on the matter. Thanks for the reply D Stroy H8!
Old Feb 20, 2004 | 11:44 AM
screamin' 85 z's Avatar
Car: 85 IROC
Engine: 355 CI n/a
Transmission: 700 r4 w/3500 Coan
Great heads, great cam, I agree the headers are a weak point..Long tubes with bigger primaries will make a world of difference, also your induction is very importand..I honestly don't know a lot about the miniram, but if it flows as good as or better than the stealth ram you should be straight...When you move up to a 383, you can expect some significant horespower gain, but mainly a very significant increase in torque due to the increased crank angle..Just remember: bigger cubes requires more air...So make sure it can get it in and out efficiently!!
Old Feb 20, 2004 | 11:54 AM
Car: 85 IROC
Engine: 355 CI n/a
If it would help, I'll give you all my specs...Pretty much the same route you're going except for the induction end:
Trick Flow 23 degree heads w/ CNC chambers
Victor jr intake w/ 750 Holley DP
Crower cam :specs--240 / 248 duration @.050
112 degree centerline
.546 / .564 lift w/ 1.5 RR (very streetable cam)
JE forged flat top pistons 10.3:1 Comp
Crower 6"rods
Stock steel crank
MSD blaster 2 coil
MSD pro comp billet Distributor
MSD 6AL ignition box
Hooker Super Comp coated Long Tubes
Stock Shocks and struts
Intrax lowering springs
Nitto Drag radials
So far this combo has been good for an 11.80 but I've only run once, so I think it's got more in it..It made 500 HP at the flywheel, So I'm sure if you do it right, You'll have no probs..I think keeping engine specs a secret is so if you have any questions or if I can help, let me know!!--Dusty
Old Feb 20, 2004 | 02:03 PM
speed88's Avatar
Engine: 383
Thanks for your help screamin! I don't think I would match your numbers, however I would definately be in the 12's based on those #'s. The LT4 hotcam is a 218/228 with a .525"/.525" (1.6 rocker). So the cam would be a big difference.
Old Feb 20, 2004 | 02:10 PM
Car: 85 IROC
Engine: 355 CI n/a
The cam is a bit smaller, but I think It's almost perfect for your induction system...I had a 94 lt1 with the hot cam, and loved it..I'd say 12's are definitely in your future! Good luck, man!!
Old Feb 20, 2004 | 04:05 PM
TRAXION's Avatar
Car: 2005 Subaru STI
Engine: 153ci of Turbo Power!
Transmission: 6-Speed
With better headers that combo will just about get you into the 11's. 12's should be very easy as long as you have a good tune and you can hook-up with a 1.6x 60ft time.
Tim
Old Feb 20, 2004 | 08:24 PM
speed88's Avatar
Engine: 383
Tim
Do you mean my 350 combo that I listed, or going with the same parts but a 383 stroker bottom end?
eightsixseven
Dec 16, 2024 01:50 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Fast355
Dec 2, 2016 06:33 PM
perZ
Aug 21, 2015 05:51 PM
ezobens
Aug 19, 2015 10:29 PM
