Knife edge crank
Old Feb 22, 2004 | 08:27 AM
widow_maker89's Avatar
Knife edge crank
Has anyone here had there crank knife edged? I called a few local machine shops to get prices but the closest i coudl get to a bal park figure was 60/hr plus balancing but he wouldnt give me an estimate on hour many hours it would take him. I would like to have this in my motor but with out a clearer i dea of cost i cant plan on it any help would be much appreciated thanks in advance Matt Manglos
Old Feb 22, 2004 | 11:59 AM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
get a crank scraper and don't worry about the knife edging.
Old Feb 22, 2004 | 04:09 PM
89Warbird's Avatar
Car: 1989 GTA Nighthawk
Engine: 389 CID TPI
Transmission: TCI 700R4
Axle/Gears: 9 bolt 3.23
Crank scraper and windage tray are better investments than knife-edging unless you just have to have that last 5 HP for about $100 per HP.
Old Feb 22, 2004 | 07:17 PM
MaxxMitchell's Avatar
Car: 87 Firebird
Engine: 5.3 76mm
Transmission: Rossler TH400, PTC converter
Axle/Gears: Strange 12bolt, 3.08s
I agree with above
Yea the extra 5HP that u gain is hardly worth the cash, but then again it is a 5hp that increases effency and does not effect emissions, of coarce the other changes also do the samething in helping just they help more and cheaper.
Old Feb 22, 2004 | 08:23 PM
JERRYWHO's Avatar
I had one done it was $675 with a balance job at the same time. The crank I had done was made by L.A. Billet and worth a lot of money. If you do that to a stock crank you will have a hard time balancing it. The best way is to get a crank with the counter weights designed for it.
Jerry
Here is a picture of a nice lightweight crank with 3.800 stroke, the crank is 44.9 lbs this short block is going in my Camaro.
Old Feb 23, 2004 | 03:08 PM
bnoon's Avatar
Car: 2008.5 Mazdaspeed 3 GT
Engine: 2.3 DISI Turbo
Transmission: 6 speed MT
Jeeeeeeeze!!! A local guy here does them for $225 with a balance included!
A new SCAT crank with the knife edge cast in is cheaper though...
Old Feb 23, 2004 | 03:16 PM
Guest
Guest
Posts: n/a
Or you could just break out the die grinder and save the $225.
Old Feb 23, 2004 | 05:05 PM
JERRYWHO's Avatar
Yes you can grind on all your counter weights with any tool you have. The only problem is getting the crank to balance after your done. If you take metal off you have to do it 180 degrees apart or add heavy metal to the area you just ground off and I have seen $400 in heavy metal in one crank before, so it's best to start with a crank made for it.
Jerry
Old Feb 23, 2004 | 05:53 PM
fireturd350's Avatar
Car: '90 Formula 350
Engine: 383 SBC
Transmission: ProBuilt S/S 700-R4 & ACT 9" Stall
Axle/Gears: 10 bolt 3.23
I had 70 to 80 bucks in heavy metal alone add'd to my stroker crank (not counting labor on it and it weighed 55 lbs before) when I had it balanced. Before I also had the 400 Eagle turned to 350 mains cost me another 100 bucks.
F-body-fan
Jan 12, 2023 01:49 PM
RS Reaper
Oct 17, 2018 07:52 PM
skinny z
Oct 5, 2015 06:23 PM
gord327
Oct 3, 2015 01:25 PM
Badass355ciz28
Sep 28, 2015 08:31 PM
