Code 45, replace 02 sensor??
Old Feb 22, 2004 | 04:20 PM
edge433's Avatar
Car: '01-Z71, 2ND GEN CAMARO, 3RD GEN Z28
Engine: 5.3, 383 STROKER, 350 TPI
Transmission: 4L80E, TH400, 700R4
I have been trying to track down an idle problem. I just got a code 45, tps is fine. I also disconnected the 02 wire while running, did nothing not even a ses light. Anyone???
Old Feb 25, 2004 | 03:52 AM
superv's Avatar
Car: 90 Iroc
Engine: 355 C.I.D. tuned port
ok, lets starts at the begining, please give a better decription about idle problem, hot/cold/rough/ect
you may not see ses light come on if your removing o2 wire while engine is cold, (open loop) cuz ecm wont begin to read o2 untell engine warms up (closed loop)
this code may be part of the problem, or the result of something else, i would note all codes, clear codes and run engine untell normal temp, if you are ok up to this point, now try disonnecting os, should set code, if not inspect for inop ecm,
when diagnosing dont worry about the code 45, worry about the rough idle, then the trouble code,
you really need a DVM and scanner if possibe, besure to inspect vacuum hose to mapsensor for cracks, IAC motor for dirty passage
and any vacuum leaks at engine, good luck!
keep writting
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
mizz0313
Aug 12, 2015 06:45 AM
squiggy2
Aug 9, 2015 09:30 PM
