Cone Air Filter
Old Mar 1, 2004 | 12:41 PM
FrozenFirebird's Avatar
Cone Air Filter
Im just curious if anyone has the K&N Conical Air Filter Part Number that I can use directly on my TPI setup. Im putting a TPI into my 81 Monte Carlo, and just want to get that air filter for ease of installation... If anyone can spare the part number, Id be greatful...Thanks
Old Mar 1, 2004 | 03:39 PM
gtaeric's Avatar
Car: '88
Engine: 305tpi
Transmission: t-5
jegs pn# 599-RC-5050 you are running the speed density system though, correct?
Old Mar 1, 2004 | 05:39 PM
Yeah, its an 87 Vette TPI Im going to convert to SD, and thanks for the info
Old Mar 1, 2004 | 09:31 PM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
I would not do it unless it was only on at a car show for looks. Your engine will be sucking in the hot air from the radiator. Track tests have proven a decrease in the 1/4 mile of 0.3 seconds. Cold air is denser than warm air. All that costs is $20.00 from GM. You could also easily make your own Cold Air Induction very easily.
Old Mar 1, 2004 | 11:01 PM
D Stroy H8's Avatar
Car: 1990 Iroc-Z
TB mounted air filter will hurt performance some. If it is under a cowl hood, not nearly as much. A stock hood will be "hot air induction" -
I would think twice about it, because there are a few very easy things you can do to improve upon a TB mounted air filter.
Old Mar 1, 2004 | 11:06 PM
D Stroy H8's Avatar
Car: 1990 Iroc-Z
I would think twice about it, because there are a few very easy things you can do to improve upon a TB mounted air filter. Home depot is a gret source for unconventional materials that work with some creativity. One example that I know works personally is mounting a 90 degree box underneath the car. It will catch air and throw it up into the engine compartment, dissipating the concentrated pocket of hot air and resulting in cooler induction, and cooler running temps.
Old Mar 2, 2004 | 02:31 AM
Im not really too worried about real power loss at this stage, Im just lookin to get something for it thats easy, Ill only have a few days to get the TPI setup and running. So, just bolting the air filter on seems to be the easiest route at this time.
Ill look into building a CAI once I have to car running, and have the extra time for it.
But thanks for the heads up on the hot air problem.
But, I would be interested in hearing what the best way would be to setup a CAI on my monte carlo, without going with the stock setup.
Old Mar 3, 2004 | 03:31 PM
D Stroy H8's Avatar
Car: 1990 Iroc-Z
Then by all means - a TB mounted filter is very easy.
I don't know about Monte Carlo engine compartments, but you just have to take a look and see which side of the fender has the most space for a filter to sit as deep as possible. Another option is mounting the filter almost toward the bottom of the car past the fender. It is really a question of how much tubing you want to bother finding a route for. Once you got the tubing figured out, mounting the filter is cake.
1992 Trans Am
May 10, 2023 07:19 PM
specialized
Jun 18, 2022 09:26 AM
Brinkkl2000
Aug 4, 2018 08:29 AM
Thornburg
Sep 1, 2015 03:39 AM
