Porting Edelbrock heads
Old Mar 2, 2004 | 06:51 AM
blackroc68's Avatar
I have edelbrock E-tec 200 heads with sdpc tpi base. I was thinking of porting them. since they are vortec will this hurt them? maybe the valves will be shrouded.
Old Mar 3, 2004 | 10:00 AM
drain89's Avatar
Car: 02 WS6 White/Ebony
Axle/Gears: Stock 3.42
I have the same heads and I'm going to gasket match them and clean up the ports with some sanding rolls. I may work on the valve guides and contour them better if possible. I'll check out the exhaust side while I'm in there and do some bowl work if needed. I mainly just want to clean them up, from the flow numbers I've seen on them they flow good already.
Old Mar 3, 2004 | 10:03 AM
drain89's Avatar
This first thing you should do is change the springs....they're junk for anything over .525 lift and over 6200 rpm. Even though there SUPPOSEDLY good to .600 lift.....BS!
beastin91rs
Oct 9, 2015 07:38 AM
italiano67
Aug 31, 2015 06:04 PM
earlpote
Aug 28, 2015 10:42 AM
86IROC112
Aug 17, 2015 02:00 PM
89-S-dime
Aug 12, 2015 11:57 AM
