Black/Purple Smoke when Warm Starting
Old Mar 5, 2004 | 01:34 AM
TheMysticWizard's Avatar
Car: 1987 Firebird Trans AM
Engine: 383 TPI...very soon
Transmission: TH700R4
Okay when I fire my car up when it's cold, I sometimes get a little bit of smoke, it is black with a purpleish tint, although most the time I get almost no smoke.
Now for warm startups - I sometimes get A LOT of Blackish Purpleish smoke, mostly after I have been driving for a while, shut it off for 5-10 minutes then fire it up. The smoke stops after about 5-10 seconds. Once again it's only here and ther, not every time I start it warm, and if it sits for more than 15-20 minutes after running before being started again, there's minimal if any smoke.
I thought it was a leaky injector, as my old injectors looked pretty old and crusty. When I pulled the old injectors 1 or 2 of them leaked a little under pressure. I replaced them with some used, although recently reworked injectors, although it did help a little, I still see the smoke here and there.
I was kinda thinking it has something to do with my Cold Start Injector, is this a valid thought? What else could it be? and why is it only here and there, not always?
Old Mar 5, 2004 | 08:22 AM
Jekyll & Hyde's Avatar
Car: 1988 Camaro IROC-Z
Engine: 350 TPI (L98)
Axle/Gears: 9-bolt 3.45
Unburnt fuel is usually white.
Burnt but running rich is black
Burning oil is blue.
I would seem to think that the injectors are leaking, and most likely the valve seals are leaking. The valve seals are normal for all aged chevys.
Old Mar 5, 2004 | 11:07 AM
chevyengr's Avatar
Car: 1990 IROC-Z 350Stealthram 11.61@120
Engine: 350 Stock Bore&Stroke
Transmission: 700R4 Auto/Vigilante 2600
Axle/Gears: 3.42 Stock 10 bolt
Valve stem seals.
Sounds like your valve stem seals need to be replaced - if you haven't already. I'ts not that hard to do. You just need access to an air compressor, a small whip hose, a spring compressor, and a spark plug adapter - to adapt to the compressor and hold air in your cylinder wall to keep the valves from falling in
I've had to do this to all the 7 3rd Gens I've had!
Old Mar 5, 2004 | 01:50 PM
Hmm, okay, valve seals... makes sense, I was just hoping that it wouldn't be that. Will this cause any harm to my engine? I am hoping to get that 305 out of there by summer and replace it with a 350, so will running it until then be a problem?
Since both of you think it's valve seals, then why doesn't it do it all the time, on every start up? I don't notice any smoke when I stick my foot to the floor, it just seems to be very occasionally on cold start up, and once in a while on warm start up.
I'm not doubting that you guys are right, just wondering why it's not all the time.
Thanks guys!
Old Mar 5, 2004 | 01:57 PM
chevyengr's Avatar
Thanks guys!
What is the mileage on the car? Have the seals ever been replaced?
This will give a good indication of whether the seals are the problem or not.
If you are going to pull the 305 motor out, just keep the motor as is. I wouldn't worry much about the seals. Just check you're oil level periodically until you get the 350 in.
Good luck
Old Mar 5, 2004 | 02:03 PM
Good luck
Mileage on Odometer is 174k, I don't know if they have been replaced, as I bought the car used and the previous owner didn't know if any engine work had been done. It runs strong, but I don't know if it's been rebuilt, I am kinda thinking not, since I've seen 305's going for 200k+.
I didn't think I'd worry about them if I'm throwing a 350 in there soon, I was just making sure I wasn't going to be blowing up the 305 soon.
Old Mar 5, 2004 | 02:06 PM
chevyengr's Avatar
VALVE SEALS!
bryan623
Mar 22, 2021 06:43 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
Red iroc-z 305
Sep 30, 2015 05:22 PM
SolarGoldRaptor
Carburetors
16
Aug 25, 2015 02:25 PM
86White_T/A305
Aug 17, 2015 12:16 AM
