what do u think of this setup
Car: 1985 Iroc-Z
Transmission: t-5
87 firebird
350 bored .30 over 10:5 compression
cam (224 int/230 ext)(503 int/510 ext)
1.6 rr's
afr 195 68 cc's
hsr
58 mm throttle bodie
24 svo injectors
hooker super comp shorties
hooker cat back
6 speed
4.11 gears
what do u think times and power on and off of a 100 shot
1.6 rr's
afr 195 68 cc's
hsr
24 svo injectors
hooker cat back
6 speed
4.11 gears
Car: 1990 Iroc-Z
I hate trying to guess numbers and et's... but I would like to say that I think that intake and head pair up is asking for more cam than what you listed
Car: 1989 Trans Am
Engine: 355 HSR
Transmission: Pro-Built 700r4 w/ 3400 converter
Axle/Gears: 10 bolt w/ 3.42 gears
Honestly, I would venture to guess that w/ traction that is a low 12 second setup. Buddy has the same cam in is LT1 w/ ported heads and FLP LTs, running 12.3s w/ a bad #7. That is just my guess though. May be a 12.5 or higher w/ those headers though. That is before the 100 shot...
After... who knows!!!
LT1Formula
Oct 8, 2015 08:34 PM
