Injector Timing & Shift Points
Old Mar 11, 2004 | 01:45 PM
Charlz B.'s Avatar
Car: 87 IROC-Z
Engine: LB9
As I understand TPI, the injectors recieve pulses from the computer. The pulse rate changes as the engine revs and the transmission shifts gears.
I recently had the transmission rebuilt in this car, and now the problem is this. The engine seems to shift gears before the transmission does. The reason I say this is that I can feel the engine change it's rpms before I feel the next higher gear engage. Also, when you want to downshift to passing gear, it requires a considerable amount more pedal, and the engine bogs down for a half-second before the gears shift.
This wasn't the case with my old transmission. It seemed it perfect sync and pulled very strong. Now it seems like I've lost power because something is getting the wrong signal or is out of adjustment.
Someone help! I can't get an honest opinion out of a mechanic around here, and I'm exhasperated.
87 IROC-Z 5.0
Old Mar 11, 2004 | 04:50 PM
poncho@home's Avatar
Car: 2004 BMW 330Cic
Engine: 3.0
Transmission: 6 speed
adjust your TV cable. Do a search on how to do it.
It's very important this is properly adjusted and very easy to do
Old Mar 11, 2004 | 05:37 PM
razor's Avatar
Car: 1992 GTA
Axle/Gears: 4.10
https://www.thirdgen.org/newdesign/tech/detent.shtml
jklein337
Sep 19, 2018 06:23 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
ezobens
Aug 19, 2015 10:29 PM
gwade12
Aug 8, 2015 08:17 AM
