Ported plenum
Old Mar 11, 2004 | 03:00 PM
Christos's Avatar
Car: 1986 Iroc Camaro
Transmission: Th700R4 Jr. Raptor
Ported plenum
It wasn't too hard to do. Nothing pretty, but I did knock out the EGR blocks, and also cut and smoothed down the cast around the runner holes too.
First time i've used a dremel tool, but overall I would say anyone could do this easily. Tough part is putting everything back on the car...
Christos's Avatar
Old Mar 11, 2004 | 10:46 PM
F-Bodeee's Avatar
Car: 1991 Pontiac Trans Am
Transmission: Borg Warner T-5
very cool pictures
Old Mar 12, 2004 | 12:55 AM
Christos's Avatar
Thanks.
Old Mar 14, 2004 | 07:23 PM
Slow89Iroc-Z's Avatar
Car: 1989 Iroc-Z
Engine: 350ci SBC
I would do a bit more work on the sides behind the TB holes.....smooth it out some.....
Old Mar 14, 2004 | 09:37 PM
jfreeman74's Avatar
Car: 1985 Iroc-Z
Engine: 1 BA 305 TPI
Transmission: Probuilt 700R4 - 2800 Stall Midwest
Let us know how it runs after you put it on. I have heard this doesn't do much for a 305. I'd like to know how it works out for you because I am considering doing this when I do my heads and cam.
Old Mar 15, 2004 | 12:30 AM
D Stroy H8's Avatar
Car: 1990 Iroc-Z
Every CFM counts. You might want to enlarge the TB bore more as well as the runner entries.
Old Mar 18, 2004 | 10:59 PM
dj haf's Avatar
Car: 1990 IROC-Z
Engine: 350 L98
what would porting the plenum and the space behind the tb do for power? and how exactly do you port the walls inside the plenum?
Old Mar 19, 2004 | 03:46 PM
D Stroy H8's Avatar
Car: 1990 Iroc-Z
It just removes airflow obstruction. Right behind the throttle bore, there are these two little walls that stick right into air travel path... they get knocked down. Also, where the air enters the runners (runner entries) can be enlarged. Basically, it gives the plenum a more "throttle responsive" interior. It's good for it too - stock cars benefit, and modded cars of course benefit more.
Old Mar 19, 2004 | 04:39 PM
Christos's Avatar
My car is pretty screwed up, so I'm not sure if it will go back on or not.
Reid Fleming
Oct 10, 2015 09:56 PM
toronto formula
19
Oct 6, 2015 12:27 PM
bplessy
Sep 30, 2015 12:14 PM
