High idle at startup
Old Mar 11, 2004 | 04:40 PM
Ovrclck350's Avatar
I have a high idle at startup that goes anywhere from 2K-25K, and then gradually down to where it belongs. Happens every single time since I put all the TPI back together. I've triple checked all the vacuum lines and even replaced some that I thought may be the problem. Any other suggestions? IAC reset?
If so, lemme make sure I have the process straight. Put paper clip in A&B, turn key to ON for 30 seconds. Then disconnect IAC (with key still on?), then start the car (paper clip still in?). Then kill it and hook the IAC connector back up.
Old Mar 11, 2004 | 07:13 PM
383 rocket bird's Avatar
Insert paper clip, turn ignition on but do not start car, should hear fan running, wait 30 seconds, disconnect IAC, turn ignition off, remove paper clip, start car, adjust idle screw These are the steps as best as i can remember. -John
Old Mar 12, 2004 | 11:06 PM
Ovrclck350's Avatar
Ok I did the procedure and it started up PERFECTLY fine the first time after I was done. However, after that, it does the same thing.
IROCtometal
Sep 20, 2015 11:08 PM
IROCtometal
Sep 9, 2015 10:01 AM
bamaboy0323
Sep 3, 2015 06:07 AM
IROCtometal
Sep 2, 2015 02:01 PM
