TPiS EGR Blockoff Plate on new setup.
Old Mar 12, 2004 | 01:36 AM
prOject-IrOc's Avatar
Car: 1990 Iroc-Z
Ok, I bought a used Edelbrock HiFo TPI base awhile back from someone here at tgo. Anyways, i have the whole new tpi setup sittin in my closet and plan on installing it soon (slp runners, afpr, ported plenum, #24's, bbk tb), but the base has the TPiS egr block off plate on it. I don't have to worry about emissions, so should i leave the plate on?
Will it throw a code if its not disabled? Hurt performance?
Old Mar 12, 2004 | 01:31 PM
gixxer9's Avatar
Car: 86 IROC
Engine: 6.2
Axle/Gears: 10 Bolt 4.10
Josh, it will probably throw a code if egr isn't disabled in your prom. If you are currently using your egr, you might as well keep it functional, and then sell that shiny block-off plate, lol! It is a topic of debate on whether the egr robs you of power, but I don't believe that it does. I removed it just because I was going to a miniram (or so I thought, lol), so I burnt my prom for no egr.
Mike
1992rs/ss
Jan 31, 2025 05:10 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
Sanjay
Aug 12, 2015 03:41 PM
