throttle body questions
Subscribe
Mar 14, 2004 | 11:22 AM
i am new to the whole tpi thing.i've been working on tbi's and carbs.my question is about the throttle body.there r a bunch of fittings on it and i don't know where it all goes.i know one on the passenger side goes to the valve cover for ccv but thats all i know.can someone post a pic or explain where they all go?any help would be appreciated.
i looked in my chiltons book but came up with nothing......
Reply 0
Mar 14, 2004 | 12:27 PM
http://chevythunder.com/fuel%20injec...um%20lines.htm
See if this web page can help you
Reply 0
Mar 14, 2004 | 12:41 PM
yeah they definatly help, but are the other ones cooler lines or something?like on the iac motor housing there are a coulpe.what r those for?
Reply 0
Mar 14, 2004 | 01:01 PM
The fittings on the bottom of the throttle body (the one that comes in from passenger side and exits more toward the drivers side facing the front of the car ) are for coolant, but you can bypass it with some hose to keep hot water from heating up the air in the throttle body.
Reply 0
Mar 14, 2004 | 01:17 PM
so basically i can just plug the 2 that r on the iac housing,correct?
Reply 0
Mar 14, 2004 | 01:23 PM
Quote:
The ones on my car are just open. I didn't want hot coolant going through my throttle boby
Reply 0
Mar 14, 2004 | 01:28 PM
why would coolant evan have to pass through that housing?
Reply 0
Mar 14, 2004 | 01:37 PM
thats for winter driving up north when it 30 below. GM didn't know where the car may be Canada or Miami
Reply 0
Mar 14, 2004 | 02:46 PM
by the way the motor is going into a 67 camaro.i am going to eliminate the purge canister so i guess i can just plug up the ports on the throttle body, right?
Reply 0
Mar 14, 2004 | 03:21 PM
i just checked out my throttle body.there is 1 more real small one on the botom, what is this for?egr maybe?
Reply 0
Mar 14, 2004 | 08:19 PM
Yep, EGR solenoid.
Reply 0
Subscribe
