Engine stall
Old Mar 15, 2004 | 06:46 PM
nitrospaz19's Avatar
Car: 86 Trans Am.....
Engine: 305 T.P.I
Engine stall
My car just decided after hitting 100,000 miles that everything was gonna go. My master cylinder went, Alternator, Front Brakes, Speedo cable snapped I think, Power antenna went, Check engine light, Main rear seal, Radiator cracked..... Well anyway on the way driving to work my car stalled twice. It has never stalled on me. I am really worried about it. My Rpms would bounce while I was driving and when sitting at a light a couple of times the RPMS would shoot up to like 1000 and my car would jerk forward. I think my Idle Air Control Valve might be going once again. It seems loose but I am not sure....Any help would be greatly appreciated...
P.S I think my trans is slippen to...*** play a funny joke on me hahahahaha
Old Mar 18, 2004 | 08:22 AM
formula_novice's Avatar
Car: 1989 Firebird Formula
Engine: 383 Stealth Ram
Axle/Gears: 3.73 9 bolt Posi
My car used to jerk forward like you are describing. It turned out that my IAC sensor was fully compressed and covered with carbon.
I would check that first. If that is not the problem, I would check the fuel pump.
Hope this helps.
Old Mar 18, 2004 | 07:47 PM
Engine: 305 T.P.I
I changed my I.A.C valve like 4 months ago.....I don't see how it could of went bad again. This damn car si costing me a lot of money lately. I spent 1500 on it and it still aint running right....Also anyone know of someone who could rebuild a trans for cheap in new jersey?
Old Mar 19, 2004 | 08:07 AM
Have you checked the fuel injectors or the fuel pump?
Infested
May 22, 2018 11:56 PM
Wade787b
Sep 29, 2015 01:15 PM
Bryan F
Aug 18, 2015 02:28 PM
Jake_92RS
Aug 17, 2015 09:42 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
