wiring harness replacement
Old Mar 17, 2004 | 11:51 AM
mmcdjs's Avatar
Car: 1991 Pontiac Firebird
Engine: 3.1 V6
Hello! I am wanting to change out my 3.1L SD engine from a 92 firebird and put in a 350 TPI unit. If I stay with the SD set up, can I keep my existing wiring harness and just add two injector plugs?
thanks
Old Mar 17, 2004 | 03:33 PM
mmcdjs's Avatar
Engine: 3.1 V6
Ok. if the 350 TPI uses the 730 ECM and the 3.1L uses the same 730 ECM , and the only difference is the Memcal, then why wouldn't the wiring harness hook up the same way? I don't know what the difference would be between the SD 3.1L harness and a SD 350 TPI harness. TPI uses the same type of two coil connector like the 3.1L, I think, so the only difference would be the connections? the 3.1 has these:
oil pressure
coolant temp
fan control (only 1 fan instead of 2)
iac
tps
injectors (only six instead of 8)
a/c compressor
alternator
knock sensor
egr
MAP sensor
distributor
incoming air temp sensor
brake
tranny connector
wouldn't all of these be the same on the 350 tpi system?
Old Mar 17, 2004 | 04:18 PM
viperwsu's Avatar
Car: 91 Camaro RS
I've done that same swap. The V6 harness won't work without lots of splicing and chopping. For one, the alt and the a/c compressor are on opposite sides, so you'd have to chop up the harness to switch them. I think the TPI air-injection pump is different too. I don't remember the other specifics, but I looked into using my V6 harness and found it would really be a hassel to convert it to the TPI config. You would be better off getting the real TPI harness.
Old Mar 18, 2004 | 09:43 PM
mmcdjs's Avatar
Engine: 3.1 V6
Ok. I've gotten the wiring diagram from the chevythunder.com web site for the 350 TPI ECM, and Alex Altvater is going to give me the ones for the 3.1L ECM tomorrow. So, I should have a pretty good idea this weekend if I can really use the same harness or if I'll need another one.
thanks everyone for the information and help! I'll keep ya posted on what I find out. If anyone wants those diagrams, just email me at dalesimpson@insightbb.com.
dale
Old Mar 18, 2004 | 10:20 PM
SweetRide45's Avatar
Yeah, let us know what you find out w/ those diagrams. I was given a swap over chart a while back, and the diagrams look pretty much the same. Change about 2-3 plugs, 2 more injector clips, and your good to go. I will be doing a swap in the upcoming winter hopefully...the info you find out would be much appreciated
Old Mar 19, 2004 | 04:55 PM
mmcdjs's Avatar
Engine: 3.1 V6
Hey would you happen to still have those diagrams for the swap? Which connectors did you have to swap over? I've looked over the 3.1L wiring diagram in the haynes manual, and compared it to the wiring diagram for the 5.7L in the same book and they're not the same. The diagram in the book is not the same as the one I found on Chevy thunder.com either tho.. so I'm not sure which one is correct.
Old Mar 19, 2004 | 07:37 PM
I'll post it on here so everyone could see. If it's wrong, let me know...from what I know though, the highlighted ones are the only differences...
Hope it helps!
Old Mar 21, 2004 | 06:12 PM
gen3z's Avatar
Car: '92 droptop bird
Engine: 5.7L,mild cam etc.
Transmission: modded 700r4 w/2600
i have modified the v6 harness fears ago but the car had no egr,smog controls,custom chip deleteing all smog and egr stuff,much easier to get the appropriate dash and harness.
midge54
Sep 2, 2020 07:13 PM
crt454
Interior Parts Wanted
Jun 23, 2017 02:25 PM
TheJoeY88
Dec 31, 2016 07:30 PM
Ikes 91Z
Dec 9, 2015 03:49 PM
Reddeath210
Oct 6, 2015 08:20 AM
