stock specs?
Old Mar 17, 2004 | 10:52 PM
stingerssx's Avatar
Car: '88 Firebird Formula 350
Engine: Built 383 TPI
Transmission: Built 700r4
Axle/Gears: 9 bolt, 3.27:1 Posi
stock specs?
I just bought the perfect car, an '88 Formula 350. But, I might need to rebuild the motor, and I want to beef it up a little. But I want to know what the stock specs are, like I know that it has 9.5 comp, but that's about it. I may just go ahead and get an Edelbrock cam, and just port match the intake and heads.
What is the stock duration, lift and lobe seperation of the cam? And what is the rocker ratio? What are the injectors rated at? How about the fuel pump?
By the way, it's an L98, 350 TPI with a 700 r4 trans, 9 bolt rear, (unknown gears at this time) and Edelbrock headers, and full exhaust. Thanks in advance.
Old Mar 17, 2004 | 11:11 PM
jfreeman74's Avatar
Car: 1985 Iroc-Z
Engine: 1 BA 305 TPI
Transmission: Probuilt 700R4 - 2800 Stall Midwest
Check out the tech articles. I think it shows a lot of the specs.
Old Mar 17, 2004 | 11:22 PM
MdFormula350's Avatar
https://www.thirdgen.org/newdesign/tech/techdb.shtml
this should help with most questions.
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
Genopsyde
Oct 7, 2015 08:35 PM
SLNTSCPE
Aug 22, 2015 09:15 PM
Exxon Limited
Aug 9, 2015 08:13 PM
