LT1 block under a TPI heads/intake possible?
Old Mar 22, 2004 | 05:59 PM
HM Murdock's Avatar
Car: 1988 Formula and 1995 LT4 Z28
Engine: 305 TPI and 361 LT4
Transmission: M5 and stalled A4
Do they line up at all? I have a 305 TPI M5 Circa 1988 that needs a new shortblock...And I have a complete LT1 2 bolt short block that I pulled out of the 95...Will they work together?
Old Mar 22, 2004 | 08:22 PM
wako29's Avatar
Car: '86 Caprice Classic
Transmission: TH-700, completely built
I would try and use the LT1 heads. They are A LOT better than the L98 ones. Also, the LT1 can rev way past the powerband for the TPI, so you wouldn't be able to pull anything past 5k, which is way before redline for the LT1.
In short? Get another LT1 intake, or do whatever you can, but keep the LT1 block on a short runner intake or expect to not be able to tap all the power from the LT1.
Old Mar 22, 2004 | 08:52 PM
OMINOUS_87's Avatar
I think he is talking about running 305 heads.
Old Mar 23, 2004 | 02:50 AM
HM Murdock's Avatar
For now, yeah. i'm trying to do this on a budget. I know LT1 heads are much better, I even have a set of LT4 heads...But they aren't for this car...
Old Mar 23, 2004 | 11:03 PM
85TransAm406's Avatar
Car: 1985 Trans Am
I would think you might have head gasket sealing problems in the area around the coolant ports between the heads and block, as the LT1 block has a much larger port than the stock heads, but it might be ok if you use the LT1 head gaskets. I don't know about cheaper as you would have to run new accessories because of the lt1's cam-driven waterpump.
Old Mar 24, 2004 | 11:28 PM
HM Murdock's Avatar
Is there no way to use the waterpump off of a 305/350 TPI(belt driven)? Or is this just a waste of energy to attempt?
Old Mar 24, 2004 | 11:36 PM
Car: 1985 Trans Am
the entire front of the block/accessory mounting points are different.
Old Mar 25, 2004 | 12:00 AM
HM Murdock's Avatar
OK, that's the kind of info I was looking for. Now way in hell I'll be doing that now.
midge54
Dec 27, 2019 04:14 PM
midge54
Jan 29, 2017 07:00 PM
theurge
Aug 21, 2015 12:46 PM
sreZ28
Aug 14, 2015 07:48 PM
Sanjay
Aug 12, 2015 03:41 PM
