Cam Specs
Old Mar 25, 2004 | 10:46 PM
White91GTA's Avatar
Car: 1991 Trans AM GTA
Engine: 5.7L TPI
Cam Specs
Just curious what everyone thought about a cam with the following specs:
296/304, .539/.558, 112
I have a guy that is very knowledgeable on engines and their components doing the research for me to get me the best setup he can find that will still be able to be driven on a daily basis.
Old Mar 26, 2004 | 06:54 AM
Fevre's Avatar
Car: 89 Formula
Engine: 355
Depends on what the rest of your set up looks like. If you are running a stock set up then :nono: but if you have upgrades such as better intake, heads, exh, etc. then
Old Mar 26, 2004 | 07:12 AM
White91GTA's Avatar
Engine: 5.7L TPI
exhaust has been changed, running straight pipe into dual race bullets. planning to install an lt1 intake, and the heads are somewhere down the road. the guy that is researching the cam for me is also trying to find the best heads for the combo.
Old Mar 26, 2004 | 02:15 PM
D Stroy H8's Avatar
Car: 1990 Iroc-Z
By all means it is a good cam for your future setup. As of right now, with a stock L98 top end and good exhaust, it is still too much. Leave it in the box until you have your heads and intake ready to go
Old Mar 27, 2004 | 09:19 AM
HiTech5's Avatar
Car: 1986 Pontiac TA
Engine: 383
Axle/Gears: 3.70
I like to look at the .050 duration numbers.
An advertise duration of 296/304 sounds like a big cam.
I am running a solid roller that has an advertised duration of 280 and .050 of 242.
If you decide to run that cam, try to bump compression to at least 10.5-1.
By the way, you WILL need a higher stall torque converter.
My cam of choice would be the LPE 74219.
www.geocities.com/dzperf
Old Mar 27, 2004 | 10:46 AM
White91GTA's Avatar
Engine: 5.7L TPI
What needs to be done to bump the compression up to 10.5:1. I am going to be getting the tranny rebuilt before I get the cam and will be running a 3500 stall TCI converter. Also, will I need bigger injectors for that cam?
Old Mar 27, 2004 | 10:48 AM
formularpm's Avatar
Car: '89 Formula
Engine: 355
Axle/Gears: 9 bolt
Flat top pistons and your stock 64cc chambers will put you near 10.5:1 static CR.
Old Mar 27, 2004 | 01:35 PM
D Stroy H8's Avatar
Car: 1990 Iroc-Z
Hmmm, you could also go with a thinner head gasket. That will yield a half point in compression (bump it up 0.5).
They seal just fine, just put it on right.
Jorlain
Oct 8, 2015 01:57 AM
BAMiller
Sep 14, 2015 06:38 PM
ericjon262
Sep 11, 2015 06:07 PM
angel2794
Sep 8, 2015 06:22 PM
Formula_88AE
Sep 3, 2015 01:47 PM
