2.73 to 3.73 how much faster in 1/8 mile
Old Mar 28, 2004 | 07:42 PM
tpi iroc's Avatar
Car: 86 iroc
Engine: 355 400hp
Transmission: 700r4 race built
Axle/Gears: 4.10 posi
I've got an '89 formula 305 tpi i have full exhuast, lt1 cam and every other little bolt ons. my fastest time with 2.73's is 9.4 sec. in 1/8 mile and a 2.02 60 ft. i just got 3.73's havent got them in yet but just wondering what my time would be in an 1/8 mile. THANX
Old Mar 28, 2004 | 09:00 PM
stuart's Avatar
Car: 88 gta ....89 formula 350
Engine: 5.7......383
Transmission: heavily reworked 700r4
your gonna love the new gears, i just made the same swap and the difference in them is unreal. the 3.73 gears will make it feel like a new animal. it complements my mods perfectly........
Old Mar 28, 2004 | 09:21 PM
wako29's Avatar
Car: '86 Caprice Classic
Transmission: TH-700, completely built
don't be surprised if it knocks a full second, or even more, off the 1/8 mile time.
Old Mar 28, 2004 | 11:36 PM
OMINOUS_87's Avatar
Well, if you really plan to max your ET you should plant a set of 27" slicks out back to get that thing hooked. Running 3.73 leaves you out of breath with a TPI at the traps. A 27" tire will hedge that risk and keep you in your powerband for the full run. Street tires are also gonna want to spin spin spin.
Old Mar 29, 2004 | 07:46 AM
John Millican's Avatar
Car: 1997 Jeep Wrangler
Engine: 4.0L
Transmission: 5 speed
Axle/Gears: 8.8 rear, 4.56 gears, 4:1 transfer
Won't happen with just a gear set change. I will say he'll still be in the 9's (1/8 mile). The reason is that the low gears will spin him right through his usable rpm range. In theory you should cross the 1/4 mile traps just over your peak HP rpm.
For his 305 even with a full exhaust and cam I wouldn't go over 3.23's or max 3.42's unless something is done with the stock heads and intake.
Old Mar 29, 2004 | 10:50 AM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
I am putting the 3.42 in my 9-bolt. Should be in the car and have everything running by May. The 3.42s are what everyone on this board, mechanic friends and comp cams said would be best to run. Of course that is for my 305(it will actually be 335). Other people run them and love'em.
Old Mar 29, 2004 | 11:31 AM
mikobu3's Avatar
3.42 's in a 9 bolt rear
impossible , you mean 3.45 's
Old Mar 30, 2004 | 08:58 AM
Tibo's Avatar
Car: 1991 Z28 Vert
My bad.
hectre13
Dec 11, 2023 08:14 AM
Orr89RocZ
Apr 25, 2016 08:28 AM
1986Z28OWNER
Dec 13, 2015 10:19 PM
Regal105
Aug 23, 2015 03:45 PM
